Question about LG WM-1832C Front Load Washer
It pumps in water but doesn't spin, starts beeping and the letters LE keep flashing on and off. I have an LG front loader, what's the problem?
    Sergeant:
  • 239 Answers
Le means hall sensor or wiring is bad
Posted on Apr 24, 2010
I have a LG Tromm with an LE error code. I just replaced the hall sensor
With a digital volt meter you need to measure the ohms value of the hall sensor. It has 4 wires. White red blue and gray. With the meter set at 20k ohms check hall sensor at the control panel. From white to blue you should read 9.5 K ohms. Same with white to red. If u get 9.5k ohms on both readings u have a bad main board. However to me I think your pump is bad. LG washers will not spin if they don't drain.
Apr 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
What does the LE flashing mean? Water won't drain out of washer.
LE means that the motor sensor has failed and needs a technician to come out and repair the unit. To remove the water, turn on the unit, press the spin speed button once and press start. It will drain the water out and spin the drum.
Jun 15, 2011 | LG WD-1280FHD Front Load Washer
I have letters le flashing on my lg front loading washer it won't spin
The code means the machine is not getting enough rinse water. Remove the hoses from the back i=of the machine, pull out screens, cold water is blue tab inside connection on washer, hot water is red. Clean screens and insert them back into the appropriate connection. Use a stiff brush and water to clean. Reset the machine by disconnecting power, press start/pause button(blue button on right) for at least five seconds, reconnect power.
Sep 25, 2010 | LG WM2277HBW XL Front Load Stackable...
Front loader won't spin, just after 2 mins up into the cycle it comes up with message le. Can you help please?
Hi just read your posting.Now I need to know the make and model of your machine.It sounds like you have an LG front loader.LE on the LG front loaders means your HALL SENSOR which is attached to your motor is faulty.Please reply with model number and I am sure I can help you.Looking forward to your reply.
Sep 11, 2010 | Washing Machines
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
Will not spin
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jun 11, 2009 | LG WM2688HWM TROMM SteamWasher
LG WASHER
Unplug your machine for a few minutes or more and plug it back in. This will fix the LE error most of the time.
Apr 27, 2009 | LG WM-2277HW Front Load Washer
We have an LG front loader washing machine that will not spin even if we take all the clothes out of the machine. It might spin once or twice but then the LE code is displayed.
first lets be clear what letters you are seeing. capital letters I or L. I E is a water inlet error and LE is a locked motor error. since your motor is obviously not locked up it is your hall sensor that is on the motor. if you remove the rear panel you will see your direct drive motor on the tub. there is a 5 pin connector on it that is a hall sensor (4 wires) (this senses rotation speed and direction) White to gray is 10-15 Vdc, check the ohms with a multimeter white to red or blue should show 10Kohms. red and blue send a pulsating 10vdc signal back to the control during operation. check wires for wear and check for loose connection. you may find it necessary to contact LG for parts.
May 04, 2008 | Washing Machines
Washer doesn't spin
Try to replace the capacitor and let me know with your results. Good luck!
Sep 01, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM-1832C Front Load Washer Logo
447 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
