Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1994 chevy truck 4.3L v6 will not stay running
1994 chevy truck 4.3L v6 fuel pump working fuel filter new, will start with starting fluid will not stay running. what could it be?
Check your ECM fuse
Posted on Nov 29, 2011
Car will not start but will crank
it sounds like there is no fuel to engine. so remove fuel filter and see if it is restricting the fuel, it may be plugged. make sure the new fuel pump is working. it may be just a blown fuse in fuse box. have a good day!
Mar 14, 2014 | Chevrolet Camaro Cars & Trucks
My 1994 chevy p/u 1500 V6 chuggs when trying to start and it never completely starts
Will it start on starting fluid sprayed into the throttle body ?
Have you checked base fuel pressure at the injectors ?
Apr 23, 2013 | 1997 Chevrolet K1500
I have a toyota 4runner that has a problem starting. I sprayed starting fluid in the throttle body and it would start and continue to run. Now it will start and will not stay running. Does this mean I need...
Yes, it sounds like the that there is no fuel getting to the motor. The fuel filter is the first place to start. Then you can move on to the pump. Sometimes if the pump wont start you can get it going temporarily by hitting the bottom of the fuel tank with a mallet.
Mar 17, 2010 | 1994 Toyota 4Runner
Parked the truck and now it wont start,,new fuel pump/filter.will run for a min if sprayed with starting fluid but wont stay running yes has gas in it 1995 chevy s10 4 cyl
check change the fuel filter and check the vacumn to the fuel pressure regulator also check the fuel lines to make sure one isnt collapsed as well
Jan 21, 2010 | 1995 Chevrolet S-10 CA Edition
1994 Chevy Astro 4.3L Vortec will not start. Has new fuel pump, filter and completely rebuilt distributer. Has spark and fuel but will not start even with Starting fluid. Any ideas?
yep!!! the main port injector is either stuck!! or its screen is topped up!! its under the top plenum assembly in the center of the intake valley
Jan 17, 2010 | 1994 Oldsmobile Cutlass Supreme
'94 S 10 Blazer V6 Vortec EFI. Fuel pressure good, new fuel injectors installed, fuel pump works ok. Only starts with starter fluid sprayed into air intake. Any Suggestions?
your statement is fuel pump work ok, have you tested for proper fuel pressure. just because the fuel pump works it could have less pressure needed to start the engine. maybe the fuel filter is plugged. start out by replacing the fuel filter, if this doesn't fix it, you need to pressure test the pump. even 10 psi reduction in pressure will allow the engine not to start.
Nov 03, 2009 | 1994 Chevrolet S-10 Blazer
1994 chevy s10 blazer turns over, won't start
try replacing the fuel regulator,or is the oil cap on tight?the fuel regulator works on base vacumm
Sep 05, 2009 | 1994 Chevrolet S-10 Blazer
94 chevy k3500 wd 6.5lturbodiesel
Check your lift pump. It is on the framerail. If that is not working check your oil pressure sensor it is behind the fuel filter. The lift pump does not get voltage if the oil pressure switch fails.
Jun 23, 2008 | 1994 Chevrolet C/K 3500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
396 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
