Question about Jenn-Air JMW8527C Electric Double Oven
Jen Aire oven / micro combo unit. Display code F7.
Jen Aire oven / micro combo unit. Display code F7. Spoke with Jen Aire and they said to replace display. Have replaced the display and still have a code F7. Model # Jen-JMW8527AAW
  • yapper7 Apr 25, 2010
    What probe are we talking about?
  • Anonymous Mar 26, 2014
    need manual
  • 523 Answers
Change the probe
Posted on Apr 24, 2010
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a jen air propane oven and four stove burner and it is flashing a the code f7-1 and saying call a a tech. Please help the beeping is very annoying
Hi, the error code implies that the Function key shorted or stuck..
You need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 20, 2010 | Jenn-Air JJW8530C Expressions Collection...
I have a Jenn Air Oven micro combo wall unit.The oven shows an error code F1/F7 with continuous beeping. I have to turn power off to get rid of it. But then I cannot use the mocrowave-any solutions?
Hello- The code described F1/ F7 indicates a 'stuck' key on the control panel. The problem is fairly common, and is not caused by computer. The panel is actually more expensive than the computer. On site diagnosis is needed to confirm. The switch is on a circuit board behind the panel and is not serviceable. Find a good service tech in your area to check it out. Wish I had good news, but I installed several of these under 1 year warranty period.  So- let me know if this info helps- have more if needed.   Thanks- Ed
Mar 17, 2010 | Jenn-Air JJW8530C Expressions Collection...
How to fix F1 error code on jen aire oven
HI There
I have this code for you to read and this is helpful. Let me know how it goes.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.Thank you for writing to fix ya.
Best Regards Richard
Jan 05, 2010 | Jenn-Air JGW8130A Electric Single Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven Door Jen-Aire Single Oven won't shut all the way.
you have bad receviers probably. did you set anything heavy on it latley? sometimes you can realign the door by sticking a peicee of 2x4 between the door and the frame and closeing the door to pop the hinge out a little thatt sometimes solves the problem with out haveing to replace the hinges and the receivers
Jan 04, 2009 | Jenn-Air JJW8530C Expressions Collection...
Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Jenn-Air JMW8527C Electric Double Oven Logo
314 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
