Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My X300 PTO will not engage. Safety switch on PTO will not let motor turn over while engaged pre-start.
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 218 Answers
SOURCE: Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
Posted on Jun 30, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
Why does my oto shut off when engaged and motor shuts off but motor will keep running if pto is turned off
You have a bad safety somewhere, heres a few places to check, your seat switch if thats bad it thinks theres no one on the the mower and it wont let you cut grass, reverse switch some mowers wont let you cut in reverse in case kids are around, brake switch which should be working since your able to turn on the mower, check your pto switch as well could be bad but my guess is the seat switch let us what you find
May 17, 2016 | Garden
My blade will not stay engaged to mow. how do I fix the problem?
When you say will not stay engaged you are saying that it comes on then cuts off ? If you turn on the PTO and it engages and the mower is not moving does the PTO stay engaged and for how long (if OK then need to check connections for PTO ) . If it is not engaging at all then we have to look at interlocks / safety switches . Give me some Details
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 18, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Engine powered down going up hill then recovered, PTO stopped, now engine will not turn over
safety switch,unhook the ground wire from coil,if it starts then a safety switch is bad,also might need a new ign switch.
Apr 21, 2015 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Leplease explainon the safety switchs on mtd models660-679 work? I beleave my model is an intek twin. thank you
The safety switch beneath the seat is only one part of the several interconnecting safety features of the modern riding mower. If the system works properly, you must be seated for the mower deck to operate. The tractor will continue running with the Power Take Off disengaged if the parking brake is set before the operator leaves the seat.The seat switch consists of two electrical contacts normally separated by an air gap. A spring creates an open space between the two contacts. Mounted between two plates, the switch's spring compresses under the weight of the person sitting in the operator seat and completes an electrical circuit. With the switch closed the tractor's ignition system can be switched on with the ignition key. If the operator stands, the spring forces the gap open and interrupts the electrical ignition circuit. The safety circuit allows the riding mower motor to continue running if the PTO is not engaged. When the parking brake is set a second switch in electrical parallel with the OPS closes. This bypasses the safety switch under the seat. If the operator stands, the parking brake switch still completes the ignition circuit.The mower blade turns only when the PTO engages. If the operator should leave the seat with the blade turning and under power, injuries could result. The mower blade would even continue spinning at full power if the machine overturned. To prevent this type of accident, engaging the PTO deactivates a connection in the original circuit and completes a second circuit in series with the OPS switch.
If the operator leaves the seat with the PTO engaged, the ignition interrupts and the machine stops. Until the PTO is off, no combination of settings will restart the mower.
Apr 05, 2011 | Garden
I had just started cutting grass with my John Deere L120 riding mower when the blades stopped turning. I thought the belt had broke or come off so I pulled into my garage to investigate. I turned the mower...
You have several safety switches on your unit. The engine should not start if the PTO safety interlock is engaged. Be sure PTO switch is off.
If the sarter Does Not Work Or Will Not Turn Engine Brake pedal is not depressed.
or the PTO is engaged.
Battery terminals are corroded. or Fusible Link in starting circuit is blown - (Not likely unless bad wires) Here is a link to your wiring diagram (maybe your model)
http://www.postimage.org/image.php?v=Pq1tOfiS
Notice how the starting circuit goes through the brake pedal (must be depressed) and the PTO switch (must be disengaged) and that the PTO only works with operator present. Print that page while link still works.
Aug 11, 2010 | Garden
I have a white outdoors riding mower....the mower shut off when i engage the pto...is the switch bad?.....can i by-pass it?....how do i test the switch????
Check the safety pressure switch under your seat. When you engage the PTO and get off the lawn mower, it will kill the engine. I had the same problem; drove me nuts. I thought it was the switch that is compressed when the PTO is engages. It wasn't. It was the safety under the seat. Bypassed and it worked fine. Ordered a new switch from a local repair shop. Good luck.
May 26, 2010 | Garden
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Apr 25, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
423 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
