Question about LG WD-12124RD Front Load Washer
LG WD-12124RD How do I remove the front panels?
LG WD-12124RD How do I remove the front panels? There is a leak. Not sure where it's from, but dripping from bottom of front panels. possibly coming from the drain filter at bottom left front.
    Scholar:
  • 39 Answers
Hiya,
most machines now open from the back you will find 2 or 3 screws/bolts at the top holding on the top section if you un screw those then slide the top back slightly it should unclip allowing you to take off the top this should expose some more screws or bolts that will be holding on the front & sides, if your machine is leaking from the front you could have a leaky door seal too so you may want to check that before starting to take it apart.
Hope this helps
Posted on Apr 23, 2010
I have a washer machine LG model WM2455MG and it smells terrible inside and it needs a treatment clean inside but i dont know how to, neither what to cleanit with. please help
Hello, it the inter tube seal that gets mold and other debris under this seal. I would say that most side door washing machine suffer from this aliment., Check with LG support and see what the have to eliminate this common occurance in side load washing maching Try a cup of vingearn when washing a load of clothers. GB...stewbison
Sep 13, 2011 | LG WD-12124RD Front Load Washer
I've just done a wash and dry. I can't open the door, and 'cd' is displayed on the panel. I don't have a manual - is the code for 'cool-down' or is there a fault? It's an LG intellowasher...
Sorry but I do not know your particular machine but here is how you should be able to obtain a manual-
You will need to type into your search engine/web browser 'lg washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 14, 2011 | LG WD-12124RD Front Load Washer
Washer dryer 8 - 4kg code WD-1457-RD It has come up with AE half way through a wash -- how do i fix it?? Thanks Kate
Did u figure out an answer to this Kate? this as just happened to ours and can't work out what it means! Aaron
Dec 22, 2010 | LG WD-12124RD Front Load Washer
I have LG WD -1050F Intellowasher 7kg front load washer, while operating time getting water leakage under front door. need solution.
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Jul 26, 2010 | LG Washing Machines
Water leaking after i have installed a new drain pump in LG
Obviously you need to find the leak and repair it...duh
Mar 12, 2009 | LG WD-1280FHD Front Load Washer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
LG WD-12124RD Front Load Washer Logo
126 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
