Question about Cuisinart CBT-500 SmartPower Premier Work Top Blender
Cuisnart CBT-500W Won't turn on?!
Won't turn on at all, no lights, no spinning. Was working fine one day and now its dead?! Is this worth having this repaired by Cuisinart or buy a new one?
2 Suggested Answers
SOURCE: replace the blade driver clutch on a Cuisinart CBT-500
I had this same problem. It was solved but let me tell you it was a nightmare and we were almost sure the blender would be destroyed at least 3 times during the ordeal.
Here's a hint: the thread is on opposite to a normal screw thread so that it gets tighter as the blender spins.
Steps:
1. Take the base off the blender and pop out the motor.
2. Turn over the motor and remove the round rubber part at the bottom. You will see a flathead screw. This is where you grip the shaft that the cursed brass coupler thread is attached to.
3. Find someone else to help and also a large strong flathead screwdriver.
4. With a friend holding a screwdriver in place at the bottom, grip the top brass thread with pliers (or better yet a pipe wrench) and twist it the opposite way you normally would.
5. Become extremely frustrated by the fact that the screw thread is made of cheap metal and strips instantly and that the brass thread is also cheaply made and rips right through your pliers / wrench.
6. Find a hack saw and a hammer.
7. Cut the brass thread off with the hack saw. Hammer the stubborn remaining pieces of it off with a screwdriver. Be prepared to cut off half of the shaft.
8. Eventually you should have hammered / sawed the brass thread off. If the shaft and motor are still intact, you can now screw the new coupler on (remember - its backwards). We had only about half of the shaft thread left and it still worked ok. Make sure to do this after you put the motor back in place with the shaft poking through the top of the case. Don't worry too much about how tight it is. As I mentioned its on backwards to tighten the coupler during normal use.
9. Replace the casing and screws, don't forget that rubber thing at the bottom.
10. Curse Cuisinart and make a drink, you deserve it.
Posted on May 13, 2008
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
Need a motor for a cbt 500bw cuisinart
Cuisinart websites for both Canada and the US have parts ordering services; however they do not list parts like blender motors.
I woud suggest you contact their Customer Service to inquire if and how a motor may be made available.
Customer Service contact information is available here:
http://www.cuisinart.com/support.html
Jun 13, 2012 | Cuisinart CBT-500 SmartPower Premier Work...
Power light blinks and blender won't turn on
Probably just a fuse. Also try a different outlet. Check the manual for fuse location and other possible solutions.
Download Cuisinart CBT 500 Manual at Bob Manuals
Apr 11, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
My blenders just stopped working. do you have any sugestions
Consult the manual for troubleshooting tips. Other than that you may want to get a new blender as repairing it would be more costly than the unit itself.
Jan 16, 2010 | Cuisinart CBT-500 SmartPower Premier Work...
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Blade won't turn in Cuisinart Duo Blender -- not motor
You have to unscrew and disassemble the blades - pretty easy, just take two rags and grab the blades with one (so you don't cut yourself), and then turn the rubber piece on the other side COUNTER CLOCKWISE, opposite of what you would do to loosen. the rod that runs in the middle that's connected to the blades on mine was all corroded, so I sprayed it down with WD-40, took my Dremel to it and smoothed out the corrosion, added some fresh grease ($2 tube goes a long way), washed the other parts with some Dawn and dried completely, reassembled and it runs much better! Not sure how long it will last, but I have a feeling that one time I ran the blender for a long time instead of pulsing, and the grease that came with it couldn't handle the heat from it turning so long. Anyway good luck!
Jun 25, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Cuisinart CBT-500 blender won't work
(0) unplug unit (1) Remove the bottom 4 screws, cover plate and motor shield ( 2) unhook the white motor wire from its binding clip ( 3) locate the plastic sleeve with the fuseable link (4) cut the sleeve and test for continuity between points on either side of link with ohmmeter (5) if no continuity, clip out fuseable link and and solder the white wire back together (6) cover with tape (7) rebind to other wires (8) replace bottom and check. This worked for me.
Apr 13, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Cuisinart CBT-500 SmartPower Premier Work Top Blender Logo
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
