Question about Boating
I have a 60 hp johnson that i am having trouble getting started after i replaced 2 pistions in also i am having trouble with the timiming do you turn it cw and then ccw
    Top Expert:
  • 50,320 Answers
You need to figure out where top dead center is by checking piston location thru the top spark plug hole .we had a factory tool for this but a long small shafted screw driver might work . take it SLOW tho as you could poke thru the top of piston .
Posted on Apr 27, 2010
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Aug 04, 2014 | Seloc Johnson Evinrude Outboards 1973 to...
When starting 1989 Johnson 60 HP will only start when the choke selonoid lever is turned 90 degrees. Have replaced selonoid.
When you push the choke button insure the purple wire is getting power. if it is, insure the black wire is getting a ground, if it is then I suspect the carbs are clogged and will need rebuilt, if not then I suspect the ignition switch or power supply to or from the switch is having issues. At any rate it may be the best idea to get it to a reliable repair facility for accurate diagnostics.
Apr 28, 2014 | Boating
I have a Johnson 70 outboard motor and I'm having
The moter has locked up is it 2sroke or 4sroke if 2 did you have oil in the fuel ?
Apr 29, 2013 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
Jun 20, 2009 | Boating
Engine knocks cold ok hot
if its at the top end its pistion slap
if its at the bottem end(of your engine) its a crank shaft bearing.
with out going into extream detail,
a ting sound at the top is a pistion slap.... replace all your pistions posibly over hual the engine.
a dubble knock that gose with rpm but sounds 2 knocks very every fireing of the pistion is a crank bearing..... replace your crank shaft bearings.... all of them b/c metal gose threw an engine extreamly fast and will destroy other beraings. this knock on start up will turn into a knock all the time, then a very louad knock that will end your engines life.
unfortunetly the answer is engine rebuild and fast.
May 30, 2009 | 2003 GMC Envoy
Boating Logo
42 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
