Question about Zebra 105Se Thermal Printer
Zebra 105se printhead issue
My zebra 105se has ablinking printehead light - it blinks steady orange color light and nothing is happening on the printer - media does not advance ?
  • 38 Answers
The controller thinks the printhead is still open. If it is open, close it.
If it's closed, it's likely that the sensor flag on the rear of the shaft has come loose and is no longer interrupting the photosensor. Remove the rear panel and inspect the flag while you move the printhead handle. The flag is supposed to be in the opening of the sensor when the printhead is closed and latched.
Steve Weinrich
LazerTek, LLC
Posted on Mar 30, 2008
What is the cause of supplies blinking red color
The printer it is in error state? Any other LED it's blinking or lighted? Do you have any message on display? Please verify if the supplies are on the correct path. Do you use adhesive labels? Verify if there is any label (or pice of label) stiked on the media sensor. You can locate the media sensor using the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
Apr 24, 2014 | Zebra 105Se Thermal Printer
We have a 105Se Zebra when it is printing in the middle of the bar code it does not print or is very light. We have cleaned the printhead and it still has the void on the barcode. We did notice a crack on...
Power off the printer and press and hold the pause key for 5 seconds while powering on the printer. This will start printing a bar across the width of the printhead. You should be able to determine whether it is a printhead issue or platen roller or both. Recycle power to exit diagnostics.
Oct 06, 2010 | Zebra 105Se Thermal Printer
My zebra 105se printhead light is blinking yellow what could this mean? I have tired replacing printhead and two board inside of printer (one smaller board that printhead wiring connect to and larger board...
The printhead light blinking usually means that the printhead is open. Is this happening with the printhead locked down ? If this is the case, the problem is with printhead open flag. It is located on the electronic side of the printer. You need to take off the side cover (with printer turned off). The lever that raises and closes the printhead is attached to a shaft (the pressure toggle is also on this shaft). Follow this shaft to the electronic side of the printer.
At the end of this shaft, there will be a black rectangular piece of plastic. This is the head open flag. When printhead is closed, the flag is positioned at the six o'clock position between two optic sensors. When the printhead is opened, the flag rotates clockwise to about the nine o'clock position. If the HEAD OPEN message appears when the head is closed, then the flag is out of position, usually it has become loose on the end of the shaft.
The flag is attached to the end of the shaft with an allen screw. Make sure the head is closed, position the flag to the six o'clock position between the two sensors and tighten the screw. this should take care of the problem.
Hope that helps !
Apr 26, 2010 | Zebra 105Se Thermal Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
Can I print in color with a Zebra 105se
Thermal printers don't have any 'color' of their own; the 'printed' text/numbers are actually only areas subjected to heat from the printhead which exposes the color of tiny beads of ink that are on the paper itself by melting them. Use a fingernail to 'score' the paper and you will see it change color just as happens in the printer.
Oct 14, 2009 | Zebra 105Se Thermal Printer
Label peeling
Sometimes the peel bar gets worn out and isn't very sharp anymore (replace). This will affect the peeling. Also try increasing the printhead pressure with the printhead toggle.
Jun 03, 2009 | Zebra 105Se Thermal Printer
Printing solid black across the label.
Sounds like a defective printhead.
Reinstall the old one to see if the problem remains or not.
Steve
Jun 25, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se missing line
Try cleaning the thermal printhead. Zebra makes thermal printhead cleaners or you can use a qtip and some isopropyl alcohol.
Make sure the printer is turned off before doing this.
May 19, 2008 | Zebra 105Se Thermal Printer
Printhead light is flashing
the light indicator on the machine blinks one (1) green and then (six) yellow, over and over again. what does this indicate? a few weeks ago it blinked 7 times and i had to change the ink cartridge holder.
if(zs>0){w(''+x2+'#b">Get the answer below
');zSB(1,3);w('
Mar 23, 2008 | Zebra 105Se Thermal Printer
Change printhead
You would need to replace the printhead and the main logic board.
You proposed change is not feasible.
Sorry.
Feb 20, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
148 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
