Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition the wet laundry and press restart it may take just a few seconds while machine tries to spin before clothing is, once again, concentrated on one side of the machine - sometimes, the washer will finish the spin at this point but most times it throws the laundry to one side and becomes unbalanced. This just started a week ago.
  • 335 Answers
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Posted on Apr 24, 2010
Maytag mah9700aww,will not spin(laundry soaking wet)
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
,.,./l;
Mar 05, 2011 | Maytag Neptune MAH9700 Front Load Washer
My neptune washer will not drain the water
heatman101
Dec 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
I heard my Maytag Neptune shake hard today when a load of laundry was going. I assumed the spin cyle got got offline for a second. The washer seemed fine. Then I did another load of laundry. While it...
do NOT call the Blue guys from Sears,,,he told me it would cost more than $2000 to fix a machine that will wash but not spin or drain ( I could get it to do both by pushing certain buttons). It is now outside and I have a used $215 washer that is doing great.
Nov 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune front load washer does not spin all water out every time. Water can be rung out of clothes at these times.
Hello there:
The clothes are wet after spinning or at the end of the cycle please try each one of these solutions that i have provided below
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Draining neptune washer
The sloshing sounds you hear are supposed to be there. Actually, it was there when you first purchased the washer and had never used it before. It's part of the balance system. When the machine goes into high speed spin, the balance system kicks in. The water portion of it is forced outward by centrifugal force. Now when the machine slows down and stops, the water settles back down so that when you reach in and turn the drum by hand, you can hear it sloshing about.
Hope this helps,
SG
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
264 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
