Question about Watches
Lost my crane sports hrm watch instructions and don't know how to work it?
SOURCE: Triax CV10
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Posted on Apr 20, 2007
SOURCE: Crane and Viceroy ladies RC watch
Have found this site where instructions can be downloaded.
http://www.precisionclocks.co.uk/Watches.htm
Hope this helps everyone with the same problem.
Posted on Aug 02, 2008
SOURCE: need instructions for Timex 1440 Sport watch
http://assets.timex.com/instructions/w140Instr.pdf
Posted on Dec 01, 2008
SOURCE: crane sports watch change time
Use top right (tr) button to select 'Settings'. Then press bottom left (bl), then bottom right (br) to select time setting. Bottom left adjust the time, when you are finished press top left to set. Other thigs such as alarms etc can be set in a similar way.
Posted on Sep 09, 2009
SOURCE: crane sports watch MD15200 Lost instructions to
i cannot figure how to set my crane sports rist watch
Posted on Aug 07, 2011
I just received a brand new Garmin FR 60 with HRM monitor strap and ANT USB from Amazon. I followed the directions to use the strap[wet the electrodes, strap it over my chest, with the Garmin logo facing...
navigate using mode button to enter into watch's menu tree for settings/ sport/ run/ heart rate and turn on the heart rate monitor to hopefully detect and scan for the garmin ant+ protocol heart rate strap!
Sep 22, 2011 | Watches
How to the HRM working
I assume that you do not have the instructions for your watch.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 19, 2010 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
Crane sports watch MD15200 Lost instructions to enter weight ,height etc
Jan 08, 2010 | Watches
Crane sports watch change time
Apr 02, 2009 | Watches
I bought a Forerunner 50 with HRM and Footpod. Initially the footpod wouldn't work, but HRM would. So changed the battery and footpod is fine. However, HRM now won't work. Just replaced the battery in that...
I had a similar problem. First my hrm worked and the footpod did not. Then I tried to pair manually (for the umpeenth time) when the hrm was too far away, and I lost that pairing, and it still didn't find my footpod. Then I wet the hrm sensors and tried pairing again and then it picked it up. Finally, I switched batteries in the hrm and footpod and then it picked up the footpod. Now I'm headed to the store to stock up on batteries. Kinda upsetting that I have to buy batteries when I just got the thing, but probably costs less than the postage for sending it back!
Feb 21, 2009 | Garmin Forerunner 50
Can`t pair Garmin Forerunner 50 with footpod
I've been having the same problem. I couldn't pair my footpod, but my heart rate monitor was working. I've only had the 50 for about eight weeks.
I reset the watch, holding view mode and Start/Stop at the same time.
This didn't do any good.
I swapped the battery in the HRM with that in the foot pod. The foot pod synched the HRM didn't.
Solution duff battery. I'd change yours it will probably do the trick.
Hope it helps
John-Paul ( AKA OldGreyWizard)
Jan 10, 2009 | Garmin Forerunner 50
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
(1) reset the watch
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Watches Logo
863 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
