While booting my desktop, it stops at a screen before windows and says "no NVRAM" I turned it off and walked away from it for an hour and then it booted to windows. Now I am afraid to turn it off! What's up with it?
  • 4,281 Answers
NVRAM is a generic term for Non-Volatile RAM. Meaning, RAM that does not loose its contents when it looses power. CMOS is not Non-Volatile. If you're CMOS battery dies and you shut off power, CMOS will loose its contents.
So you need to change your cmos cell also reset all settings to defaults.
There is not big issue with computer just pull cmos cell for 10 minutes from motherboard if your cmos cell is3 years old then change cmos cell.It is round cell on motherboard.
Also reattach the ram memory into it's slot on motherboard.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Apr 23, 2010
What does mean konica minolta cd370 error code
CD370 errors occurs when• Multiple errors are detected by the
abnormal check of each NVRAM data.
You need to reset the printer's NVRAM . First find out how.
It isn't mentioned in the KBizhub350 User Manual, as required by government. Any fraudulent activity is also kept on the nvram. (copy bank notes).
Jun 26, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
I'm unable to use my desktop PC cause black screen says: reboot and select proper boot device or insert boot media in selected boot device and press a key _ what can i do to fix it?
I'm Electronics Telecom Engineer,webdesigner ,seo, PC support professional,Online teacher via skype I'll help YOU
to fix problem REMOTELY Please feel free to contact me anytime via e-mail at besubmitbe@gmail.com, or on Skype at bpshbp
Jan 13, 2014 | Acer Computers & Internet
So, I just recently purchased the Alienware Aurora computer, and everytime I have turned it on, it says Setup is preparing for first use. I have already updated everything for it. This morning when I...
Sounds like there's some corruption in the windows install. Did you purchase this computer new? if so I would call Dell cause it will surely be a warranty issue. If not you will need a Windows 7 install disc. If you have a disc put it in the disc drive and boot to it and do a repair on windows if this doesn't help you will need to completely reinstall windows 7. Hope this helps
Dec 27, 2010 | Alienware PC Systems Alienware Aurora High...
Cannot seem to find how to enable the sata ports. I've tried all the solutions suggested with no good outcome.
With the SATA drive properly attached to the cable, try clearing the NVRAM (CMOS). By clearing the NVRAM (CMOS), the system will redetect all the installed hardware including your new drive. Just follow the procedure I have outlined below. After the clearing of the NVRAM (CMOS) you may get a warning at boot up about the Diskette Drive if you do not have a floppy drive installed in the system. If that happens, just go into the BIOS Setup and disable the option for the Diskette Drive. The error message will be gone on the next reboot.
  • Reboot system and enter the BIOS Setup by pressing F2.
  • Turn on Caps Lock, Scroll Lock and Num Lock.
  • Press ALT + E then ALT + F (should hear beep) then ALT + B
If you need any further assistance please feel free to contact me again.
Please rate me if this solution works for you
Thanks......Have a great time
Jun 13, 2010 | HP Compaq Presario SR1200NX (PN211AAR) PC...
After installing windows security updates, i could not get windows vista to come up and i don't have a recovery disk from Acer for my Acer Aspire T180 PC Desktop.
I run into this all the time, thank you microsoft!
First, shut it down and take a break, make sure you power the computer completely down to a cold boot. Walk away for ten, fifteen minutes.
Then when you come back boot into your setup (bios) screen, to do this is different for each manufacturer, some require you to hit del, some F2, some F10... when you get there Change your boot order to anything other than what it currently is, and save it. Reboot. let windows try to start. if it does, great! If not, reboot and Go BACK to the setup screen and change your boot order BACK to what you NEED/WANT it to be and save again and reboot. This SHOULD take you back to a windows startup of either a repair or safe startup screen. DO NOT REPAIR! Boot normally. The updates lost a startup configuration that is written INTERNALLY to windows. Since you altered the hardware configuration by changing the boot sequence around, windows had to rewrite this and away you go. On a laptop it gets a bit more confusing as you have to do this without the battery in place or it will continually write the data to the hard drive under the laptops auto powerdown/save features that a desktop does not have. NOTE: if this does not work any other bios change other than clock/calander will force this dmi configuration change. but typically the boot sequence is the safest to alter, as you do not risk messing up critical setting with this one.
Feb 16, 2010 | Acer Aspire T180 PC Desktop
How do I repair nvram ,, when I start windows XP it takes over 1/2 hour to load windows ,checking NVRAM this only started this week after a power cut
Sound like the battery for the bios has died, open up the case of you pc and you will see a silver battery to dissimilar to a watch battery remove this and go to your local hardware or PC retailer and get a replacement, first time you fit it you will still take a while to boot but them you should be ok, if not you possibly have a piece of failed hardware in your PC or corrupted BIOS, if this is the case you can download BIOS updates from the motherboard manufacturer, but to be honest if the BIOS is corrupt it's usually time for a new board or PC "Sorry"
Dec 03, 2009 | Computers & Internet
I have 2 GX520's that are buzzing when trying to boot
If your computer beeps during start-up:
  1. Write down the beep code
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM read/write failure
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer failure
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
1-3
Video Memory test failure
1-3-1 through 2-4-4
Memory not being properly identified or used
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller test failure
3-3-1
NVRAM power loss
3-3-2
Invalid NVRAM configuration
3-3-4
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No timer tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-1
Memory failure above address 0FFFFh
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-2
Failure to decompress code to shadowed memory
4-4-3
Math-coprocessor test failure
4-4-4
Cache test failure
Apr 11, 2009 | Dell OptiPlex GX520 PC Desktop
After loading from both recovery disks, installation stops
THIS IS A NORMAL PROBLEM WITH ALL WINDOWS VERSION. YOU CAN NOT SOLVE THE PROBLEM. JUST RE-INSTALL THE WINDOWS TO YOUR PC. ONLY THIS WILL HELPS U.
BYE
KETAN
Feb 18, 2009 | HP Compaq Presario Media Center SR1750NX...
Turn on power button and it starts booting up then...
here is a start.... restart and immediatly as it starts to reboot start repeatedly start hitting F1.... this will bring you up to the screen asking if you want to boot in safe mode.... YES
once you are on... get online and im me.... sparkyallen1@aol.com I will walk you through the rest of it
Dec 25, 2008 | Acer Computers & Internet
Computers & Internet Logo
David Payne
David Payne
