Question about Plantronics CS60 Wireless Headset
Blinking red light -
I have blinking red light on the left side of the holder, the blue light that would indicate it is working is not on and there is a blue light indicator on the earpiece.
It won't work - I've checked all of the connections.
Any ideas?
  • 5603 Answers
SOURCE: my headset will not hold a charge CS70VT
The only thing is to check the voltage output by the charger... usually 5 volts. The lights MAY blink even if voltlage is too low.
If it is OK, then battery in the headset has failed. Have the battery replaced or DIY if not under warranty.
The usual cause of this is to continue using batteries under load when one of the cells is totally depleted.
Posted on Nov 09, 2009
wb91
  • 126 Answers
SOURCE: My plantronics discovery 975 will
It sounds like you're still in pairing mode (and not paired) if the light is flashing white/red. Take a look at the following link on pairing instructions:
Plantronics Discovery 975 Pairing
If it continued to flash white/red and not pair, you may have a defective unit. Contact where you purchased the unit for a replacement or call Plantronics at 1-800-544-4660 x 5538.
Good Luck from Headsets Direct!
Posted on Apr 18, 2011
HDI Headsets
  • 537 Answers
SOURCE: When I try to charge
If this is not charging correctly it may be that the battery is no longer functioning properly. The batteries are non replaceable on this headset. If this is still under warranty (1year) you should be able to get a replacement
Here is a link to the User's Guide.
Good luck from Headsets Direct!
Posted on Oct 10, 2011
HDI Headsets
  • 537 Answers
SOURCE: The red light and blue
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Posted on Oct 31, 2011
HDI Headsets
  • 537 Answers
SOURCE: when you press earpiece to
This could be several problems, I am going to give you the one that I believe is the answer. It sounds like it may need to be subscribed again. First here is your user guide:
Plantronics Voyager 510
Plantronics Voyager 510 User's Guide
If that doesn't work, it may be that your headset is bad. If it is you can replace that with this headset:
Plantronics Voyager 510 Replacement Headset
Alpha Romeo 156 My Left hand indicator light stays on continually, does not flash. and when I turn the hazard light switch on both indicators continually glow.
Generally speaking, symptoms of a bad or failing turn signal bulb are usually the culprit...in your case, either it's the front left or rear bulb. Varies for different vehicle makes...common signs include:
  1. turn signal light staying on solid
  2. or blinking very fast
  3. or either sides of the bulbs stop blinking altogether.
To test this, make sure you reconnect everything you disconnected.
Turn the left signal light on; go to the front of the vehicle, is the turn signal bulb illuminated? If it lights up, even though it is not blinking obviously the bulb is okay. If it doesn't, replace it- problem solved. You'll do the same procedure for the rear turn signal Is that lit up? If not replace the bulb and the problem is solved.
Another common failure is when the turn signal blinks really fast, same procedure as mentioned above.
If both bulbs for the left side and right side illuminate but don't blink, the problem is in the steering column turn signal switch.
If the left or right side blinkers don't work properly at all...then check the integrated hazard warning/turn signal flasher relay- that may be defective; again, that's usually the case if both sides of the signal light don't work.
If you are blowing any fuses related to the flasher system, you have an electrical overload in the turn signal circuitry.
Feb 12, 2017 | Cars & Trucks
Tip
Colour full BlackBerry ..If you are a Blackberry user.You must read this
In BlackBerry LED indicator blinks in different colors to deliver different notifications to the user:
Blinking RED: The LED indicator blinks red whenever you have incoming or waiting communication messages on your phone - new email, new call or missed
call,
Blinking GREEN: this is Coverage Indicator light. This lets you know you are connected to a network.
Blinking BLUE:If your phone is connected to a Bluetooth device, such as a Bluetooth headset it blinks blue.
Blinking YELLOW: A blinking yellow light means it is time to charge your BlackBerry
on Dec 15, 2009 | Cell Phones
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
JBL Flip blinking red and blue
This indicates that the Blue tooth pairing with the already paired device has been reset and the JBL Flip is ready for pairing with new device. This position, red and blue blinking, can be obtained by long pressing the power buton.
Mar 03, 2013 | Harman Kardon JBL Flip black
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Blinking red light no picture
No picture or do u have a blue (or some other color) screen? And the blinking red light, is that the indicator light down by the power button that is blinking? I have the same tv and very similar problem, i have a blue screen and the red indicator light is blinking. If you have gotten ur problem fixed I would love to know how, or vise versa if I get mine fixed.
Sep 11, 2011 | Toshiba 65H84 65" Rear Projection HDTV
My O2 Atom on normal mode binks in blue colour and there is a missed call or sms blinks in orange (or red). from yesterday it blinks in green on normal mode. Can you please tell me why? Anything wrong?
The notification lights indicate:
Blinking Blue - Bluetooth On
Blinking Yellow - WiFi On
Blinking Green - GSM (Phone) On
Blinking Red - Unread message
Continuous Red - Charging
Blinking green when your GSM (phone) is on is the expected behavior.
May 02, 2011 | O2 Xda Atom Smartphone
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Plantronics CS60 Wireless Headset Logo
198 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
