Question about Candy Washing Machines
Cold wash light flashing cyle wont run - Candy Washing Machines
4 Suggested Answers
zaids
  • 456 Answers
SOURCE: cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Posted on Apr 12, 2008
SOURCE: hi my zanussi zwf1432s stopped halfway through
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Posted on May 05, 2010
  • 5 Answers
SOURCE: my washer runs in the wash cycle but when it
There should be a clicking noise when you open and close the lid switch. If you do not hear it than the lid switch could be the problem
Posted on Nov 05, 2010
Normal and heavy cyle lights wont come onwhen selected What is happening?
do you get 7 flashes of the clean light? if so, do this: Open door press: high temp, energy save, high temp, energy save, close door, open door, press cancel. then run as usual.
Jan 15, 2011 | KitchenAid 24 in. KUDP02FR Built-in...
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
My clean light flashes all the time and wont let me start the dishwasher.
Hi
Thanks for using FixYa. If the clean light flashes, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 24, 2009 | Kenmore Dishwashers
How do i reset my dishwasher when the light is flashing AND NOT WORKING
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Aug 24, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Apr 14, 2009 | Kenmore Dishwashers
Clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Washer stopped running
check the pump on the machine if its clogged it wont let the washer drain
Dec 31, 2008 | Maytag Washing Machines
Kenmore elete dishwasher flashing light clean
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 06, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Whirlpool gu2400 dishwasher
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 05, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
