Question about HP Deskjet F4180 All-in-One InkJet Printer
My printer will not print from microsoft word
Zebra TLP 3842 isn't printing
Step 1:Firstly, restart the computer and check the print queue.
After the computer restarts, double-click the printer icon in the lower right corner (the notification area) of the computer. The print queue opens.
If theprint jobs remain in the print queue,continue to the next step
Step 2: Run theFixitavailable in the link below:
Troubleshoot-printer-problems
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
Step 3: Make sure the printer is not paused or offline.
1. On the print queue menu bar, clickPrinter, and then look for thePause PrintingandUse Printer Offlineitems in the menu.
2. Make sure that there is no check mark next to either item. If a check mark displays next to either item, click to clear it.
Change-your-default-printer
http://windows.microsoft.com/en-us/windows-vista/Change-your-default-printer
Step 4:Run the fixit available in the link below to restart the Print Spooler service.
Fix printing problems by resetting the print spooler
http://support.microsoft.com/kb/2000007
You may try to add the printer locally and test
Add-or-remove-a-printer
http://windows.microsoft.com/en-us/windows-vista/Add-or-remove-a-printer
Mar 06, 2014 | Zebra TLP 3842 Thermal Label Printer
Hello guys, i´ll be very
Issue Print jobs are stuck in the print queue (spooler) on a computer running Microsoft Windows connected to the print server. Nothing prints, and the print job in the printer's queue shows a status of Printing . These print jobs cannot be deleted even on the server, and it will not disappear or print until the Print Spooler service is restarted. Solution For Microsoft Windows Server 2003 and Microsoft Windows XP Professional x64 Edition, a fix is available in Microsoft Knowledge Base Article, The Print Spooler service may stop sending print jobs to a printer that uses the standard port monitor on a Windows Server 2003-based computer . Click here to view Microsoft Knowledge Base Article 934885 (http://support.microsoft.com/kb/934885) . To prevent this issue from occurring, disable the bidirectional printing support for each HP printer driver installed. To do this, perform the following steps:
  1. Click Start , point to Settings , click Printers , right-click the icon representing the printer to be modified, and then click Properties .
  2. Click Ports , click to clear the Enable Bidirectional Support check box, and then click OK .
NOTE: Sharing a printer over a network is a feature of Microsoft Windows and not HP printer specific.
Nov 01, 2010 | Office Equipment & Supplies
My HP4360 Printer will print from the internet and print pictures from my documents but will not print text from microsoft word.
Firstly check the print settings from the microsoft word print option dialog box (you'll see this after you press the print in the winword) and from "Print what" option, select "Document" as shown below ; 4993d81.jpg
And then give the print command. Keep your printers updated, make sure you spooling is running in the task manager, you can check this by opening the task manager - processes - and from the available processes check whether spoolsv.exe is running. In rare cases, this is caused when there're many programs running on the system (overloaded). Make sure that you have enough memory (Ram). Check the usb connection. I recommend the first step, good luck. If you want further reference, please visit microsoft's website for more details on how to troubleshoot printer print failure. http://support.microsoft.com/kb/826862 good luck.
Apr 18, 2010 | HP D4360 DeskJet Printer InkJet
Deskjet 5550; Windows 7; Microsoft Office 2007; not printing
That is strange
Try changing the default to a different printer (Microsoft XPS Document Writer) see if it prints to it...
Then (If that works) try switching the 5550 back to default.
If that don't do it, uninstall thee printer, reboot and reinstall the printer.
Mar 12, 2010 | HP DeskJet 5550 InkJet Printer
I cant print word documents. It says printer is
I have encountered this problem, wherein I can print webpages, excel, pdf files, but not in Microsoft Word.
I received error "Windows cannot print due to a problem with the current printer setup".
I got it resolved by following the instructions given by Microsoft: http://support.microsoft.com/kb/826862
Specifically the steps under 'Delete the Word Data key'.
Oct 14, 2009 | Office Equipment & Supplies
Trouble printing a microsoft word document on
I have HP 3180 All in One Printer...When I try to print from Microsoft Word...I get a statement that says document is "spooling" ready to print but nothing happens. How can I avoid this step and just go to print.
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Dell AIO 942 Printer - updated driver from Microsoft
In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
Good Luck........
Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
Will not print Word or Excel Documents
pls reinstall printer and reinstall microsoft office also
Mar 01, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Prints green from Microsoft Office 2007 - Windows Vista
correct the printing settings of the microsoft office....... there is a option button in the printing dialog box check there
Oct 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
Seeker5211
Seeker5211
