Question about Fellowes 220C-2 Shredder
Makes noise blades don't move
Hello
We are having problems with our shredder. It turns on and makes a "shredding noise" but the blades don't move. Can you help me troubleshoot?
  • 215 Answers
You have some teeth missing off of one of the gears, most likely the dual gear thats driven by the motor.
razors
Posted on Apr 23, 2010
My power shredder W11C stopped working forwards and backwards. The power source is O K
Dear Edward,
Most of the shredders have a micro switch that senses if the paper has been introduced to the shredding slot, or not
These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing.
While disconnected from the power, try to check if the switch is working properly. Check if you can hear a "click noise" while moving it back and forth by using a paper clip (or a toothpick). When this sensor arm is broken, the device will not operate since it does not detect the presence of a paper sheet to be shredded (and the power to hte motor is shut off).
If this does not solve your investigation process, please make sure your power cord is fine. Otherwise, it would be an internal electric problem in the device (obviously!!!)
One additional possibility (since I have no further details from you) is that the device is on and you can hear the motor running but the paper is not being pulled by the blades - in this case gears that move the shredder blades are most probably broken (that has happened to my shredder - and I had to dump it).
I hope this gives you some light in further investigating your problem.
May 07, 2014 | Fellowes Office Equipment & Supplies
Omnitech shredder ot-nxc18pa won't power up
Dear Bruce,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that senses if the paper has been introduced to the shredding slot.
While disconnected from the power, try to check if the switch is working properly. Check if you can hear a "click noise" while moving it back and forth by using a paper clip. When this sensor arm is broken, the device will not operate since it does not detect the presence of a paper sheet to be shredded.
Make sure your power is on (not only connected to the wall - but check if there is any indicator in the shredder). If the arm is not broken and you still hear the click noise indicating the micro switch is being activated, then your problem could still be the power since there is not LED indicator in the panel of this device.
If this does not solve your investigation process, please make sure your power cord is fine. Otherwise, it would be an internal electric problem in the device.
One additional possibility (since I have no further details from you) is that the device is on, you can hear the motor running but the gears that move the shredder blades are broken (that has happened to my device).
RC
Mar 22, 2014 | Omnitech 10-Sheet Micro-Cut Shredder
Only goes in reverse
Lube might not be necessary. Unplug the shredder from the outlet. Lift it off the shredded paper bin and turn it over. It is very possible that you have a jam. If this is the case, remove as much paper as you can making sure that you don't use anything that could do damage to the cutter'shredder blades. Once you have removed as much paper as possible, place the shredder back on the bin making sure that it is aligned properly. One way of making sure is to check for any space between the shredder and bin. If you do have space make sure that you replaced the shredder correctly on the bin; you may have to turn it around 180 degrees. When you get the shredder properly aligned, use the switch (DO NOT USE PAPER AT THIS TIME) to switch the shredder from Forward (shredding) to Reverse. You may have to do this a couple of times so be patient. At this point the shredder should be working in both directions. If so, move the switch to Auto or the center position and try a SINGLE sheet of paper. If it shreds that piece of paper, then you have fixed it. Be sure not to insert more paper than the shredder is rated for. Also, unless it specifically states that it can handle staples, credit cards, etc. do NOT let any of these items run through your shredder.
If none of the above works, buy a new one - :)
Jan 10, 2014 | Techko SH1524CP Shredder
Knocking noise when shredding paper
Cross-cut shredders require monthly oiling of the cutting cylinders to maintain proper operation. Failure to oil the blades regularly could result in excessive noise during operation.
Oiling Your Shredder's Cutting Blades:
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three times.
I hope the above helps....
Good luck.
Apr 13, 2011 | Fellowes DM8C Cross-Cut Shredder
Machine won't shred. Does turn on, and goes in
You dont say make or model so...get some shredder oil into the cutting teeth where you insert the paper...especially if its a x-cut shredder..make sure once in a while you shred a piece of paper with some of the oil poured onto the paper for lubrication of the cutting blades.
Mar 04, 2010 | Office Equipment & Supplies
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Makes noise but won't shred
Had the same prob with a Schneider shredder. The roll pin that secures the nylon driven wheel to the blades shaft was sheared. Easy fix in a way but original pin was a metric size.
Jul 13, 2008 | Tech Solution TS-2550 Shredder
Fellowes 220C-2 Shredder Logo
418 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
