Question about Feiyue FY100
FY100 embroidery machine
My fy 100 embroidery machine detect that the upper thread s broken and stops but the thread is ok
  • nettunoninfa Apr 23, 2010
    my fy 100 embroidery machine detect that the upper thread s broken and stops but the thread is ok
    President:
  • 1,561 Answers
Take a very good look at the upper thread very well because it is possible that it is truly broken because for it to stop working something must have truly happen.
If after careful look and nothing was observe broken, then i advice you carry out maintenance check or service on the machine. This will help in a long way to fix the problem.
Take care
Posted on Apr 23, 2010
  • Sulaimon Jimoh Olayemi Apr 23, 2010
    I Further suggest you check the manual that came with the machine to see if there is anything like such notice or error on the manual and what it means or what it is indicating.
    Take care.
The machine is pulling through more bobbin thread than embroidery thread
Sounds like a tension issue. Try rethreading the upper thread first and then lower the upper thread tension.
Jan 27, 2013 | Brother PE770 Computerized Sewing Machine
Why does the check upper thread notice continue to come on when the thread is not broken?
I suspect fluff or lint is interfering with the sensor. Might be time for servicing.
Oct 27, 2012 | Sewing Machines
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Elna 8200 embroidery machine. Broken needle
Computerized machines need to be serviced by an authorized sewing machine technician, preferably Elna.
Diving into this may cause more problems and end up costing you more money for repair.
Mar 13, 2010 | Sewing Machines
Start/stop button is not working.
When you have the embroidery unit connected to the machine, you must have the foot pedal cord disconnected. Then it should work. As for using this machine for normal sewing, yes, it is supposed to do that. Unless you get a lemon like mine. It lost reverse, and only takes long stitches. Hopefully your luck is better than mine with this Disney "thing".
Jan 19, 2009 | Yamata FY101-1A
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
Jun 07, 2017 | Baby Lock Ellure
Top color thread showing on bottom of embroidery on a Bernina Deco 330 embroidery machine
Upper tension is too loose or lower tension is too tight.This might be a good thing. It depends upon how much it is pulling the thread under. A perfect tension on embroidery is about 2/3's lower thread and 1/3 upper thread showing on the bottom.
sewman7
Jul 09, 2008 | Bernina Bernette Deco 600
FY100
From all the info I can get it is the same chassis as a brother PE100. It used custom eeaprom cards and read .PEC or .PES files.
It could also be like the Bernette Deco 500 or 600 series. I have also seen a modification of this chassis called the EM10 by Husqvarna and it is USB direct connect and comes with software that outputs .HUS files.
Jan 29, 2008 | Sewing Machines
Singer futura CE-100 4 blinking reds lights
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Dec 23, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
Oct 30, 2007 | Singer CE-100 Futura Computerized Sewing...
Feiyue FY100 Logo
145 people viewed this question
Top Feiyue Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Feiyue Sewing Machine Expert? Answer questions, earn points and help others
