Question about Garden
Mower will not start it is a toro 22hp kroler was serviced 3 weeks ago and was runing good when i try to start now it will backfire sometimes and that is all it will do
    Problem Solver:
  • 15 Answers
Check the gap on the spark plug. Also the fuel mix may be way off. If the plug is good then try adj the fuel mixture screw. Or take it back to who serviced it and flip out lol.
Posted on Apr 24, 2010
Toro 50" ss5000 time cutter with Kawasaki 22hp engine battery wont charge. Allow me to only cut about 3 times before battery is drained.
Take battery out, charge with 12v auto charger. In a couple days check voltage 12 or better
Jun 23, 2016 | Toro Garden
How to raise the deck of a Toro SS 5000 mower above the highest factroy setting
Hi Robert:
I'd start by looking at the mechanism with the engine off while someone else moved the height adjust lever from hi to lo several times.
There will be 2 or 3 linkages that connect the deck vertically to the height adjust mechanism. Shortening these linkages should raise the cut height. If you're lucky, there should be enough clearance to allow the linkages to be drilled so that you can simply move the mounting pins into the new holes.
Or, you could make shorter linkages.
Best of luck.
Sep 30, 2015 | Toro TimeCutter SS5000 50 in. 22HP Smart...
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
Dec 26, 2014 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
Jul 24, 2014 | Toro TimeCutter SS4260 - 22HP 42 Zero Turn...
My mower will start but won't stay running
I am going to respond 2 times to this post. The first reply will be generic things to check.
First off check the oil level and make sure it is serviced to full.
If your having a lack of fuel (runing lean) you will need to check fuel flow at the carb fuel mainfold. It should fill a spray paint can lid in less than 10 seconds but teting flow rated of the main fuel line. If you have poor flow here... you need to check the fuel filter and the fuel tank outlet port for obstructions.
Good Fuel flow still shutting off.... remove the carb float bow and clean the debris from the bow' and the treaded area where the fuel solenoid mounts Additionally you will have to again remove the main fuel line and spray carb cleaner in the float needle area to flush out any debris through the fuel hose connection.
For the second response I need to know which engine is installed on your mower by MODEL number if you can locate it. (there are 3 engines) At least try to find the engine model number. If you can not locate it Brand and HP of the engine (I assume 22 hp) Thanks for choosing FixYa,
Kelly
Jul 24, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
New battery/checked voltage12 v. started 3 weeks ago. Can I get a repair manual?
these are sold on eBay, at bookstores, and at small engine repair shops. like all books someone has to write them, and someone holds a copyright on them.
Apr 11, 2011 | John Deere 22HP Hydrostatic 42" Riding...
Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
