Question about Kenwood KDW243A Builtin Dishwasher
Kenwood dish washer showing E4 - Kenwood KDW243A Builtin Dishwasher
Check the water inlet on the top of the dishwasher isn`t loose. It`s an easy fix if it is, just hold the inlet on top where the hose goes in and hand screw the plastic cap underneath thats inside the dishwasher. Mine done this and the water was pouring down from the top into the base, just follow the other tip for emptying the water from the base
Posted on Oct 17, 2010
I have a ge profile washer and I get an e4 error code
Hello Lisa;
My name is Peter. I am a retired field service appliance technician.
You did not provide any information so I have to be general.
1.) I assume this is a clothes washer and not a dish washer?
2.) What is the model number? It should be on a label on the face of the unit after you open the door.
3.) The E4 error code on your model washer is an inlet valve failure. Does washer seem to fill up with hot and cold water at a steady rate?
Mar 20, 2015 | GE Washing Machines
Air conditioner e4 error
Your dishwasher is not an air conditioner. It only washes dishes, not conditions the air.
Jul 05, 2014 | Kenwood Dishwashers
Haeir dish washer
e4 error with the temperature sensor
Fix it .
God bless you
Oct 02, 2012 | Dishwashers
Showing error code E4
check for waterleaks filling the overflow tray at the bottom of dish washer that is activating the float switch. check for defects or damage at bottom of dishwasher.
Feb 01, 2012 | Bush Dishwashers
My Kenwood Dishwasher shows an E4 error code
Howdy:) An E4 or E5 error indicate an abnormal water level which means too much inlet water. Here is the shortcut to the Kenwood PDF file with the user's manuals.
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
You can cut and paste it into your browser's address window. Your model was not indicated in your message, but the error codes are standard throughout the Kenwood models. I hope you find this useful:)
Aug 25, 2010 | Microwave Ovens
I have a Kenwood KDW12SL3A and have used it about 5 times and now it flashes up E1 near the end of the program. What can I do?
i had an e4 error and after lookin itup i tilted it forward after i done this i got an e1 error after playing about for a bit and checkin all hose's and connection , i came to the conclusion it was an air lock so i put on a 8min rinse mode and when it counted down to 7 mins paused it and toped up the bottom of the dish washer with boiling water from the keetle and started the rinse again. straight away you could hear the air lock movein once rinse mode fininshed i put onto a 2hr 36 min wash and is workin fine now. so make sure your machine is level and try this it may work
Jan 20, 2010 | Kenwood Dishwashers
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Kenwood KDW243A Builtin Dishwasher Logo
1,178 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
ray gallant
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
