Question about Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune TL when it gets down to 12 minutes left it starts flashing dc and wont finish the cycle, what is wrong?
  • 526 Answers
You could have a Clutch malfunction if the machine is a FAV6800A or FAV9800A. If that is you r machine type see this post. Clutch Fix
Post back of you have questions.....Rich
Posted on Apr 25, 2010
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune top load washer will not spin out with small loads, large loads are fine. I get the DC error at about 10 mins left in spin cycle. No amount of shifting load will solve problem
This is a Clutch issue could be a easy fix if the Tub Seal is not the root cause.
If you get no help at this forum Google This ""Neptune TL Washer FAV6800AWW""
5th post down you will find the SM and support for the "DC and UC" unbalance error codes. Good luck..............DH1200s
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have the neptune tl. When it gets to the spin cycle it stops and flashes dc in the display. I have to reclick the start button to get it to continue and finish. Any ideas? I was reading online all...
Our washer was doing the same thing. A repairman looked at today and said it's a transmission or brake problem but it may be under warranty for the parts--the warranty is for 10 years.
Dec 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My neptune TL gets down to 11 minutes left in the cycle and the the error "dc" appears...what does that mean??
You have a Clutch malfunction with your FAV6800A or FAV9800A Here is my link for the repair/replacement for the Clutch in your machine Clutch Fix.
Let me know if I have any questions on what need to be done......Rich
Mar 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont Finish Spinning stops and Flashed DC
If the machine type is a FAV6800A/FAV9800A see this Clutch repair post if you want to DIY. You will find links to the Service Manual and parts info if needed.
You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of max Wash Tub movement and the Control Board shuts the Spin Cycle down……..so thebTDS is working as designed.
The machine will make several attempts to redistribute the load before error code generation failing with dC or uC error codes.
Post back if you have questions any DIY'er with basic skill sets can do the Cluch maintenance/repair.....Rich
Jan 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't finish cycle, flashes "dc"
sounds like the timer/selector switch may be shorting out or faulty. You can test the wires to and from it with an ohmmeter.
A faulty water pump could also cause this but not as common
Nov 12, 2009 | Cars & Trucks
Neptune TL, stops at the 11 minutes to end and will not go past, I have to shut off, hit spin cycle to finish load
Hello krabby64
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
Oct 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
166 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
