Question about Microsoft Windows XP Professional
How to fix "BOOTMGR is missing" in Windows xp
  • 808 Answers
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reg in out registry cleaner
Posted on Sep 08, 2010
  • 499 Answers
Hey Mr Milebdavi try these steps
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
Posted on Apr 23, 2010
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: BOOTMGR is missing
Its already solved.Check the solution by an expert -
http://www.fixya.com/support/t411366-bootmgr_missing
Any further help let me know.
Thanks for using Fixya.
Posted on May 24, 2009
Bootmgr is missing
Bootmgr is the replacement for NTLDR in Vista and Win 7. NTLDR (NT loader) is the OS component which literally started the operating system in XP/2000. In the past I have had to use recovery console to go in and repair the OS (this is only available on the Windows disc). I would say in this case you will have to do the same, repair the operating system using the Windows disc.
This article is a how-to on fixing this issue, if you up for it:
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Jan 14, 2012 | Gateway Computers & Internet
Bootmgr is missing
I don't work in a lab anymore but when I did (in XP/2000 days) this apparently is the equivalent of the 'NTLDR not found' error, which was always bad... you would have to go in through recovery console to repair it. Evidently the BOOTMGR is the new NTLDR, so your going to have to repair the OS. Check out these links I found, and good luck!
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
Jan 12, 2012 | Computers & Internet
My laptop says bootmgr is missing and i dont know how to fix
First make sure that all usb devices are unplugged and remove all cd's or dvd's or sd cards etc.
If you are running Windows 7 or Vista you can try do a repair by hitting F8 while it boots and then select repair. If this does not work you will need a install disc. If you have Windows XP you will need an install CD to do a repair. I have attached a few links that may help explain in detail. Thanks for using fixya.
bootmgr-is-missing-error-while-trying-to-boot-windows-vista/">http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
May 15, 2011 | Acer Aspire 3050-1733 Notebook
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
Bootmgr is missing
Here is a good step by step for this. It is writen for Windows Vista but should also work for Windows 7.
Mar 01, 2011 | Acer Aspire 5315 Notebook
BOOTMGR is missing
go to a torrent and upload and save the Windows XP program to your hard drive. Try to install it from your hard drive but use your own Serial Number
Jan 31, 2010 | Microsoft Windows XP Home Edition
Bootmgr
format ur laptop and get ur problem solved
Sep 05, 2009 | Acer Aspire 7520-5185 Laptop
BOOTMGR is missing
May 24, 2009 | Microsoft Windows 95 for PC
Microsoft Windows XP Professional Logo
327 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
