Hi Got a JVC AV 32FA44 tv it won't turn on I replaced cap 973 it was blowen off the main board I found the outer covering so I could get the correct cap back in but it would still not power up I also replace caps 931 and 503 they were both low when you plug the set on now it tries to power up for 3seconds or so than it shuts down and the green power light flashes - don't know were to go from here any suggestion would be great thanks Brian
  • Brian Lange May 18, 2010
    Barbu51 I did check d432 and Q431 they both checked good in circurt they were definitly far away from the original cap that was blowen but they did check good in circuit it still does try to start up but still shuts down any further ideals that I may check thanks Brian
    yes still have the same problem with the tv do you have any other thing a guy can check to try to find the problem thanks Brian
  • 566 Answers
Hi steff
To answer your question;
If capacitor c973 , 10 mfds/50v was blown off, then you might have the following components gone as well.
D432: 1ss133 switching diode
Q431: DTC124EKA-X surface mount
Note that the transistor is a surface mount component(SMT)
Just requires some time and patience along with a magnifier to replace.
Also you can find those components on the web.
By the way also check the jumper W624 for cold solder joint.
Hope this help Good luck
Posted on Apr 23, 2010
  • Jacques Marin
    Jacques Marin May 18, 2010
    this problem still alive ?
  • Jacques Marin
    What we`ll need at this point is a schematic.
    I will look and see if i can find one.
Turned on my JVC AV-31FA44 32
Check its power regulator section and Line Output Transformer. The work is a skilled one, and only an expereinced service technician can go for ward. You must have its repair book with you too.
Apr 11, 2012 | JVC AV-32FA44 32" TV
The TV turned off, and the ON Timer is blinking
Ur power inverter board is dead.U need a new one.
Sep 24, 2009 | JVC AV-32FA44 32" TV
2003 JVC AV-32FA44 dark screen
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 21, 2017 | JVC AV-32FA44 32" TV
Jvc av-32fa44 tv--loud pop, then off and won't turn back on. buy new?
Its the power cap mine did the same thing about 11 months into daily use
Oct 24, 2008 | JVC AV-32FA44 32" TV
Thick plastic film covering glass screen got deeply scratched while moving
Hi there!
I would simply replace the plastic sheeting. Will certainly be cheaper than replacing a tube. Glass tvs don't normally come with this plastic so leave it off if you can remove it. There is a type of spray on the market for this purpose, just don't know if available in your country. Please note: It is dangerous to use a tv which had been scratched beyond 1.5mm, The glass may become unstable and implode if bumped by accident. Good Luck,JUS004
Mar 08, 2008 | JVC AV-32FA44 32" TV
No picture, No sound
Hi there!
If the set is dead after the popping sound, then it has probably blown a component due to high voltage. Everything inside a tv starts with the power supply. Nothing will work unless the power supply is 100%. I don't know what your rates for repairs are in general, but the price sounds good. The final decision is yours to repair or replace. Good Luck, JUS004
Jan 24, 2008 | JVC AV-32FA44 32" TV
JVC AV-36260 TV Problem TV won't turn on
  • blowing fuse is a short circuit problem in your tv.
  • please do not replace fuse unless you know the reason otherwise it may damage tv.
  • fuse blowing is due to
  • main filter capacitor
  • power output transistor sort or regulator short circuit.
  • good luck
Oct 21, 2007 | JVC AV-36260 TV
Dark Picture
Hi there!
The knobs you refer to, are those perhaps the knobs on the board or knobs on the flyback transformer? None of these knobs should be turned. They are preset to the factory standard and if a fault occurs the fault should be addressed, not adjustments to pots. I would suggest checking all the caps in the power supply, Line stage and video section. It may also be the video processor(in the area of the tuner section). Check for caps which are rounded at the top. This is common for dark picture. Please note: There is on average about 15000V running through a TV when switched on, please be careful and unplug when changing components or refer to a repair technician. Good Luck, Jus004
Jun 06, 2007 | JVC AV-32FA44 32" TV
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
JVC AV-32FA44 32" - No Picture, but sound OK
You could have a power supply problem as parts do go bad. Why your set faile is a mystery.. Of course if your not a technician, a TV set is NO place to be experimenting with. It only about a year old you say But get the papers on this set if you can find them and make sure as there is a 12 month warranty on this model. You should contact JVC At 1-800-252-5722 or online at http://www.jvc.com/support/. Good Luck
Aug 07, 2006 | JVC AV-32FA44 32" TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
