Question about Xantrex Technology Heart Freedom 20 12 Inverter
I need a eletrical schematic for the heart freedom 20 D, #94K1 RV power inverter so I can check it out more. It will not turn on inverter or charger. thanks, Nathan
SOURCE: I have a Heart Interface Freedom 20
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Posted on Jul 04, 2009
nitrospawn
  • 290 Answers
SOURCE: Heart Freedom 20 will not default to generator power.
First of all it is possible that the is no power going into the inverter,trace the input source to see if the connection from the generator is ok. check the fuse if it is broken if not, the contactor or switching relay in the inverter is bad
Posted on Apr 09, 2010
SOURCE: How do you verify that the unit is charging the
The really only way one can tell if batteries are being charged is assure them are topped off then trickle charge them with external charger overnight and then check the voltage is 13-14.5 VDC. If not check that battery life is not expired and exchange them if it is. ALSO... one can always extend the life of batteries (deep-cycle) by charging them with a large professional automotive unit in the high power START position over night. WARNING: Assure the caps are loose as you "boil away" the plate corrosion over night due to the very explosive H2 gas generated. No smoking!!
Posted on May 21, 2010
SOURCE: heart freedom 20. As soon as shore power is
STOP!!! Immediately have the shore power breakers checked by assuring both output legs have EQUAL output. If not they can either burn out the inverter solid states components or the main coach A/C, Generator transfer switch. You can usually check this with a multimeter but the shore power park managers usually have maintenance personnel to check and replace bad pedestal breakers. Does this help?
  • 91 Answers
SOURCE: Wiring Freedom 20 inverter
make sure your new inverter is made for 220 volt supply as that is what the red wire represents. its the other leg of a 220 circuit and should not be connected to your new inverter until you read the manual to see if it is designed for this and if so how to wire it in. it could cause you are the unit serious harm if you connect a 110 inverter to a 220 circuit. consult an rv repair shop or a good electrition if you cant find the needed info. it may actually be printed on the side of the inverter as well.
Posted on May 28, 2010
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
May 27, 2010 | Xantrex Technology Heart Freedom 30...
Inverter is draining house batterys on rv
it is possible that you batteries are bad, if you have used it for over a year you will need to replace it with new ones
Feb 16, 2010 | Xantrex Technology Heart Freedom 20 12...
Where can I find parts for my Freedom 20 Inverter/Charger near Virginia Beach, VA? The cooling fan is inoperative.
Contact Tekris Power Electronics
They are in NJ. Ph 732 938 4996
They know the Freedom units very well, I send all of my dead ones there. Good luck
Sep 11, 2009 | Xantrex Technology Heart Freedom 20 12...
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
Heart 2500 w charger inverter only shows shut down and will not start bateries are new why
if it does not start, the inverter control or power transistors that do the switching may be bad
Jun 05, 2009 | Xantrex Technology Heart Freedom 25...
Freedom 20 Inverter / Charger
1997 monoco dynasty and the invorter heart interface freedom model 20 the problem we are having is the we don't get any powere from the electric outlet and the lights don't work and there is a reading in side on wall that tells you about your electricity and it reads overload my # 817-614-7576 donna
Feb 16, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
138 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
