Question about La Pavoni Europiccola EPC-8 Espresso Machine
Virtually no crema :-((
I have a la pavoni pump espresso machine and cannot seem to find the right way to achieve quality, & substantial, crema. I use a good grind (from starbucks grinders, sorry). I left the lever, wait for the espresso to come out into the cup below and then begin pushing down hard on the lever. I do that one more time as I use the double portafilter cup.
That said, I still only get a very thin layer of crema, which goes away within a few seconds.
I have tried a more fine grind, I have tried a more coarse grind (Ive been suggested both) & still no good. I do not let the machine get to hot and the coffee grinds are at rooom temperature. But still no luck and I am completely perplexed by all of this. I feel like paying someone to come to my home and 'show' me how it is done.
Any suggesstions would be very greatly appreciated.
Thank you,
Tyler
    Scholar:
  • 36 Answers
If you have tried different coffees and grinds then i would try different packing methods using a tamper to do so. Try packing very firmly to not so firmly and see if that works. Also you might find that you need a new double filter basket. I have seen this in quite a few machines where the holes in the basket can become very slighty enlarged from what they were originally and what this does is allows the coffee to flow through the basket too quickly and therefore leaving you with poor crema by not getting a good extract from the coffee. I hope this helps.
All the best
Mr La Pavoni
Posted on Jun 02, 2010
Generally to get perfect shots of espresso you want to have proper conditions like brewing temperature and grind.
if you don't have a grinder at home to grind right before you brew then you will never achieve perfect shots. not to mention that grinder has to be of good quality or inconsistent grounds will spoil your shots.
Also starbucks coffee is terrible, try to find a local roaster so you can verify bean roast dates.
I hope this helps.
Posted on Aug 05, 2012
I'm looking the right part (portafilter or handle and cups) for my La Pavoni Duet PA-1315.
try this link
if not listed use contact us or ask
some parts may have been discontinued
La Pavoni Parts
Oct 11, 2016 | La Pavoni Coffee Makers & Espresso...
Tip
La Pavoni Lever Machine Hissing?
If you have a La Pavoni lever model espresso machine and the safety assembley on the top right hisses while the machine is heating up, all you have to do is use something hard but preferably not metal or too large and tap the safety assembly quite firmly but not to hard and this should stop the hissing. This is because inside the assembly there is a bung on a spring and sometimes it becomes stuck and just needs a gentle tap to free it up. If it doesn't stop hissing then you can remove and stretch the spring or if needs be replace the spring and bung.
All the best
Mr La Pavoni
on Jun 02, 2010 | La Pavoni Europiccola EPC-8 Espresso...
Hi there. problem with my La pavoni PL-16. No coffee comes out. The vapour its ok, it comes out but from the place the coffee should comes out, it doesnt. With or without the the filter holder. Whats...
Hi if there is Vapor coming from the grouphead when the lever is down then I would guess there is a problem with the seals around the piston and possibly elsewhere. Here is a link to a goos site that looks at repairing La Pavoni lever machines. Good luck.
DIY
dr pavoni
May 29, 2014 | La Pavoni Lusso PL-16 Espresso Machine
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
Unregulated pressure then safety valve releases pouring out steam
It seems to me that your pressure stat which is inside the base of your machine needs replacing. I would try to give it a good descale and if this doesn't do the trick then a new pressure stat is what you need. Prob around £20 if you buy it and do it yourself. www.theespressoshop.co.uk and just click on the little la pavoni machine for full parts list.
All the best
LaPavoniBoy
Apr 13, 2009 | La Pavoni PC-16 Espresso Machine
Our La Pavoni Lusso machine has not been used for a couple of months. We put water in to prime the pump, and nothing comes out. We can hear the pump going, and the heater indicator light is working. Any...
Try opening the steam nozzle while trying to pump the water through as this will get rid of any air locks. Otherwise it may be a build up of scale in the boiler or the pump itself. Try that and descale if you can.
All the best
LaPavoniBoy
Mar 07, 2009 | La Pavoni Lusso PL-16 Espresso Machine
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La pavoni professional
Make sure your filter is clean.
Jul 21, 2008 | La Pavoni PC-16 Espresso Machine
LA PAVONI PISA
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
Jan 25, 2008 | La Pavoni Pisa PA-35 Espresso Machine
La Pavoni Europiccola EPC-8 Espresso Machine Logo
394 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
