Question about Brother MFC-7820N Printer
Black lines down on printed page
When I copy a document using the automatic document feeder, I get couple parallel black lines down, close to each others on the printed page. When I copy a page from the scanner glass, or print an MS Word document, the printed pages are normal. I received a fax recently and the prints were OK, without black lines. It seems that the trouble caused by the automatic document feeder when I use it.
  • 1,110 Answers
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Posted on Apr 23, 2010
  • Mike Smith Dec 09, 2011
    Thank you. That cured the aggravating problem. I had cleaned it before, but when I read your solution, I took a flashlight and looked really close. Almost missed it again, but it was a tiny pin-point spot of something. Had to scrape it off, then re-clean the glass strip. Voila! Problem solved.
  • parentinghea
    parentinghea Jul 24, 2012
    This was a big help and solved my same problem. Thank you!
THANK YOU SO MUCH! We almost bought a new drum but didn't have to because this fixed it. It's amazing that it's the simple things. The manual for this machine said NOTHING about cleaning that glass strip.
Posted on Jan 15, 2013
Black lines on copy only when printing but copying is ok i.e km 1650
If this only occurs when using the document feeder then you will need to clean the smaller glass that sits next to the large glass that you manualy place your documents. The document feeder scans the originals over the small glass and any ink ,whiteout that may be on the glass will appear as lines down the pages
Oct 24, 2013 | Kyocera Mita Office Equipment & Supplies
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black lines running down on the Konica Minolta bizhub c252 copier?
Does this happen when you print? does this happen when you make copies on the big glass. Does this happen when using the document feeder?
Jan 23, 2012 | Minolta Office Equipment & Supplies
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp laserjet 2010 prints black line down side when printing scans from paperport 11
I have no idea what "paperport 11" is.
That being said, normally a line down the page when copying or scanning is caused by dirt on the Automatic Document Feeder glass, Not the flatbed glass. It is a thin strip of glass to the left of the flatbed scanner glass. Clean it.
Jan 11, 2011 | HP Office Equipment & Supplies
Lines of copies utilizing automatic feeder
look to the side of your big glass and you'll see a piece of glass about 1.5" wide. thats the galss that is used for scanning from the feeder. theres got to be something on that glass. possibly white-out or even a small speck of toner can cause that. look closely.
hth,
razors
Mar 16, 2009 | Brother MFC-9440CN Laser Printer
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Feb 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Brother MFC-7820N Printer Logo
1,260 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
