Question about Xerox WorkCentre XD100 All-In-One Laser Printer
The paper jam indicator on in error?
The paper jam indicator comes on and you receive error message E2. You can still feed paper from the side and get a perfect copy everytime. I have tried resetting the copier using the clear auto twice function twice. No luck. Hate to throw the XD100 out on the curb if there is an easy fix. Just put in a new toner cartridge and have another partial toner cartridge on hand.
  • 1,110 Answers
So it sounds like the machine is not feeding paper from the paper cassette. This is a common problem.
There are 2 possibilities. 1 easy and one a little tougher. The simple fix is cleaning the paper feed tires. Just pull out the paper cassette, then remove all the paper. You will see 2 felt type pads on the spring loaded metal plate. Spray these 2 pads with some glass cleaner. Dry the metal plate a little then lock the plate down and re-install the cassette without paper! Make sure the lower tray is selected for paper feeding and press the print button. The machine should try to feed a few times then shut down with a P in the display. Reset the P using the clear key then press print again. Repeat this procedure 5 or 6 times. Then remove the tray, dry the pads a bit then re-load the paper, re-install the tray and give it a try. If dirty feed rollers were the cause then this procedure will fix it. Let me know how this works out.
Thank You for using Fixya
Posted on Apr 23, 2010
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
I have an error E2. I have tried to reset the
E2 just says to insert paper and press OK, for some reason the paper is not feeding or the sensor inside is not seeing the paper. Check inside where the paper goes for any obstruction, sometimes ink pens, paper clips, jewelry, etc... fall inside the back and stop the paper from feeding. If your printer has 2 choices for paper make sure the paper is in the right tray and select the correct tray.
Feb 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper feed error message. spits it out fast and
Your printer has a fail safe mechanism that pushs the paper that it's processing out to prevent any other jams during the printing process. Your rollers must have something jamming it's movement during printing. You will need to open the printer through the panels on the back, front, and side to ensure that you see the rollers and remove any paper or debrise blocking hitched on the rollers or in the printer. You may also want to ensure that the holders on the sides of the paper tray where the paper comes in are lined up correctly. Also, make sure not to pack the paper tray to capacity. Only use the tray half full.
Nov 29, 2009 | HP Designjet 70 InkJet Printer
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
It won't work and has an Error Code E2?
Dear Shaun McKenny, I just posted a fix to a Error Code E3 which is a paper jam that had no visable paper jam..Try this...it may be that you have some kind of paper stuck in the rollers...and you just can't see it ! Turn printer OFF for at (10 Seconds) then turn it back ON and listen to hear the Feed rollers turning and Force FEED a sheet of paper into your printer...until it catches and pulls the paper through and see if some scrap of paper comes out with the
sheet ? GOOD LUCK ! Let me know Phil at
palcando@yahoo.com
If this works for you, spread the word !!
May 04, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
253 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
