Question about Liquid Video E15LCD1 15"
I have a liquid video TV and it would not turn on. I noticed that a few weeks ago the sound and picture were frozen or fuzzy for a few minutes but then it was ok after that. Any suggestions? It is model 1611008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Picture is fuzzy for the first few mins after turning on
This may be an issue with your color wheel where it isn't spinning up to speed at first but finally does after the 2 - 10 minutes. Fairly common in DLP TV's.
This could be fixed by a qualified Hitachi Servicer.
Blessings,
A/V Media Tech Guy
Nov 21, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Samsung t.v. picture going in and out
it may sound like you have a input or a output problem if you have a video un plug it from the tv. and put your Aral strait to your tv that will tell you if your video is the problem not the tv.
Jan 07, 2008 | Samsung DLP HL-P5663W 56" TV
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Screen is messed up, getting worse
What your describing sounds like two differant problems OR the power supply is causing these two problems .. One would of course be the tuner and the other would be the vertical circuit .. Your going to need to seek out a profesional if you havent a clue about solid state electronicsand A tv is not a place to experiment! Good Luck
Jul 27, 2006 | Panasonic CT-36SX31 36" TV
Liquid Video E15LCD1 15" Logo
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
