Question about Asko W620
Washer skips the rinse cycle. all other cycles work fine.
2 Suggested Answers
  • 18 Answers
SOURCE: asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Posted on Apr 02, 2007
Ariston L63S dishwasher does not rinse
Check the screen and the inlet to the pump in the bottom of the washer if it does not empty the water from the wash cycle completely it may not go to the rinse cycle.
Sep 06, 2017 | Ariston Technologies Dishwashers
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
My topload Roper washer cycles fine but stucks in rinse stage. It makes a noise on that stage. I manualy put it in spin mode (skipped the rinse) and it works from there. Please help.
Your timer is bad. There must be a pause in the timer for the neutral drain transmission to lock in.
No Pause.
No Spin.
To double check this,when the timer gets to the Spin cycle, open then close the lid.
If it starts to spin at that point the timer is bad.
Jan 09, 2011 | Roper Washing Machines
The machine starts going thru the wash Cycle and then it goes past the rinse cycle and then it shows OL after the spin cycle.. It even does this when you have no cloths in it. I went to rinse and spin...
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing machine keeps stopping on the rinse cycle and then i have to skip the cycle for it to keep working.
at any stage have you interchanged the hot and cold hoses due to a valve failure unless programmed the washer will call for cold water on rinse cycle but usually will fault if no fault occurs possible control board problem let me know how you go
Nov 05, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer Mod# TWAS750PQO, Ser# CR3520005
is it possible that the washer was overloaded? if so the agitator has little plastic "gears" that move the agitator one way only, they could have made the sound.
you can also check under the washer to see if anything (like a coat-hanger or something) is interfering with moving parts of the washer
Jun 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Skipping throygh cycles
Timer ? Are you referring to the main control board ? How much extra water is being added on the first cycle ?
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
131 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
