Question about Samsung HT-X40 System
The rear speakers and the center channel speaker do not work
I have tried to make them work but have been unsuccessful, anyone know how to do this
  • Anonymous May 12, 2008
    me neither
  • 3 Answers
I bought a Samsung HT-X30 home theatre; but have sound from only two speakers and the sub-woofer works very faintly and the rest does not work at all. Can any body be of help?
Posted on Jun 13, 2008
Hi, maybe,like my HT-THX25, my book states that sound will only be heard from the rear speakers when in DVD 5.1 or Dolby Pro Logic 11 mode, peronally I would love to hear sound from any of my speakers when TV is on lol. Geoff
Posted on Mar 30, 2008
MY REAR SPEAKERS ON FOCUS 2007 HVE STOPPED WORKING DOES ANYONE KNOW WHAT FUSE COVERS THEM SO I CAN CHECK IF BLOWN ?
There is no fuse to the speakers your rear speaker wires should run under the kick plateon drivers side broken or disconnected wire or burned out channel in radio.
Oct 21, 2012 | Cars & Trucks
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
Connectivity
you have to make sure you are on the theater mode on your amp. that's the only time that the center speaker works
Jun 10, 2010 | Pioneer VSX-818V-K Receiver
Rear speakers are dead, never got them to work. Changed front to back and rears work so speakers and wireing are good. Is it possible that because I did not hook up a center speaker this is the problem?
if its a 5.1 channels it means 2 front speakers,2 rear speakers or either the center speaker or the subwoofer.try to hook up either center speaker or subwoofer.
Jun 05, 2010 | JVC RX-888V Receiver
Rear speakers L and R not working
if its a 5.1 channel home theater,it means you have to hook up the subwoofer or maybe a center speaker to its terminal to have them all working. 2 front speaker,2 rear speaker and 1 center speaker or subwoofer =5 and amplifier is 1 so it is a 5.1 channel.hope this help..
May 31, 2010 | Sony STR-DB940 Receiver
Speaker output doesnt work
Hi when using surround sound its important to understand that not all soundtracks have a "rear channel' meaning that the rear speakers will not always produce sound. In fact the rear channels may only produce sound about 10% of the time.
Your receiver has a "test tone" which sends a tone sound through the 5 speakers you should turn the speakers up or down so that all 5 speakers produce about the same volume.
The speakers of course will have a different sound to them depending on the brand and model but just try to balance it as much as possible.
Should also point out that you need to start out with at minimum a STEREO signal and that it needs to be connected with good quality cables. If possible use the optical inputs or HDMI which is a digital signal but not all receivers have that capability.
Lastly play around with the settings Dolby is of course the standard but many receivers have Neo or other proprietary surround formats which may produce the desired effect.
Hope that helps
Jan 02, 2010 | JVC RX-558V
Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
Mar 13, 2009 | Sony Audio Players & Recorders
Center channel
Back to basic to advance:
Be sure you have all speakers connected correctly behind the receiver.If you center channel don't have any sound,it could be 7 different issues,but you could try to just hook up your center channel to either the right or the left speaker output to be sure the center channel speaker does work.
Check your the speaker wiring tip(if there is any),i will use just the speaker wire go straight to the center speaker output,go to the receiver to change it to pro-logic or dolby digital and of course you should put in a dvd in the dvd player to have a good quality movie to play the dialogue through the center channel for you test.
If you have tried the above step and still have no sound,you might consider hiring a troubleshooting master to take care of your issue.
Let me know what you need!
solutiondoct
Nov 05, 2008 | Pioneer VSX-455 Receiver
Samsung HT-X40 System Logo
459 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
