Question about Hayward SAND FILTER, PRO SERIES
The Pump is making a humming noise but will not cut on.
  • Al Kupchella
    Al Kupchella May 11, 2010
    Maybe it doesn't know the words!
    Sorry, I just couldn't resist. Best of luck getting a useful answer.
    Al K
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The motor is likely failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 23, 2010
Is Dropping The Tank On A 96 Mustang The ONLY Way To Replace The Fuel Pump? Thanks
than is the normal way . some have cut access holes thru the floorboards but it is not a recommended fix .
Feb 01, 2016 | Cars & Trucks
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
What are the side effects over years of use
Ball Bearing needs to change.there is inside the pump a mechanic seal that with the time, leaks water and rust the ball bearing balls and making rusted the shaft .
The pump at this time gets Humming when works.
Pump humming or making noise is not a good working pump.
must be quiet without noise
Aug 19, 2014 | Pool & Spa
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
Feb 12, 2013 | 2005 Toyota Sequoia SR5
Just makes a humming noise and will not cut off without unplugging.
Could be something hung between tubs or in the pump.
Would you like the service manual?
Jan 04, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Car makes humming noise gets loud and cuts off
SOUND LIKE FUEL PUMP.CHECK PUMP PRESSURE BUT MOST OF THE TIME WHEN FUEL PUMP GOING OUT YOUR HEAR HUMMING OR LITTLE WHINING NOISE.FUEL PUMP MOTOR BEARING WORN OUT.
Apr 04, 2010 | 1999 Oldsmobile Alero
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
My 05 Corolla stop running.
Sounds like you need a fuel pump. The first indication of a fuel pump issue is a hum or drone noise.
Sep 22, 2008 | 2005 Toyota Corolla
Dishwasher stopped washing just making a humming noise
humming noise is the wash pump energised but not turning.
this can be:
wash pump seized up
foreign object stuck in the pump impellor.
pump capacitor faulty - a common fault. if pump turns freely by hand but not when energised, then the fault is probably the pump capacitor - cheap part
Aug 22, 2008 | Whirlpool Dishwashers
Hayward SAND FILTER, PRO SERIES Logo
190 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
