Question about HP Officejet 6310 All-In-One InkJet Printer
How to get repaired a broken paper guard and how much would it cost?
Paper jammed. Finally got paper out, but machine will not work. Motor runs, whines, but teeth do not turn. What can be done to repair?
Stripped the gears getting the paper out, or unseated them. Take it apart and see if anything is out of place, hopefully you can snap it back were it goes.
If anything is broken it is usually more cost effective to purchase a new one rather than repair.
Sep 26, 2015 | Office Equipment & Supplies
How can I buy a replacement guard strip?
I do not know it you can or not. Below is a link to the manual; look for your model and down load it. It might be of some help to you, Good Luck.
Fellowes Shredder Manuals
Oct 08, 2014 | Fellowes Products - Powershred Shredder...
How can I replace the guard on my saw
If it is steel u can use J B weld for steel or u can wire weld it if u have the equipment if not take it to a local body shop they will have the equipment to fix it
Jan 30, 2014 | Saws
A small white plastic piece has broken off the bottom of the printer. I am not sure where it has come from. I think the paper carrier may have been forced and caused this problem. Now the printer is not...
In my experience, what you say might be correct. The small white broken piece could be the arm that comes down and touches the top sheet of paper in the tray, so it knows how much paper is loaded. When there is no arm, it can not recognize that there is paper loaded, thus NO PAPER FEED. I have fixed one of these in the past, but I had 2 identical printers to mix and match parts. I am not sure what it will cost you, you would have to call the repair center and find out. It took me about 2 hours to fix, so I hope a professional could do it faster than that.
Mar 14, 2011 | Brother DCP-585cw All-in-One Wireless...
Fellowes Powershredder, making clunking noise and ceases to shred
2 probably causes
to check this 1st unplug the machine
now take the top off ,there are 2 screws underneath the front edge of the cover assessable when the door is open, and 2 on the back you will want to back the shreddr up to a table when you take off the top (the sensors and switches are all still connected so this takes the stress off of the wires)
now you will need to remove the blade guards there are screws at the left and right ends of the guards,
once these are removed you should have a pretty good view of the blades, look for any visible obstruction (part of a binder clip or paper clip or metal closure from an envelope for example)
if this wasn't the cause try this
on the side of the blades there is a fan wheel that is connected to the motor. When you turn the fan with your hand you can manually turn the blades, typically you will be able to turn it to a given point and then it will be increasingly hard to turn, you might also notice that the bar on the outer edge of the blades begins to bend at this point. These bars seem to break under fairly low stress and having one break will also produce the symptoms you described. replacing one of those is a costly repair, (cost is largely because it is very time consuming,)
Jul 08, 2010 | Fellowes 220 Powershred Strip-Cut Shredder...
Printer not picking up paper from paper tray
1). take all the paper out of the paper tray.
2). look at the printer pickup roller while you enable the printer to print a test page.
3). if the roller is not turning, and hear click sound, then you need to take the printer to be service. The gear that runs the pickup roller is broken.
4). if the pickup roller truns, but you still hear the click sound, then most likely the secondary roller gear is broken. You still need to bring it to be repair.
call the repair shop and find out how much it cost and how long, It is cheaper to get a new printer than to have it fixed.
Jun 03, 2009 | HP Photosmart C6100 All-In-One Printer
Replacement LCD?
When the display is cracked Sony charges a dud fee in additional to the cost of the replacement panel that is about the same price or more than the replacement LCD panel. They can't refurbish a defective. Add to that about $400 for in-home labor, then taxes and the repair will cost the same or more than a new TV. Example, $1200 panel cost, $1500 non-return of rebuildable dud, $400 labor, Taxes = $3300+
If you could replace the panel yourself, all you would save is the labor cost and the tax on labor charges.
Basically if any flat panel screen (LCD or Plasma) is physically damaged, the TV set is junk. They do make pretty abstract art pieces though. You could sell the whole set for parts on Craigslist or eBay, but don't expect to get much.
Aug 11, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Paper feed broken
You broke a part. It is a low end machine. The repair will cost close to the repalcement cost of the machine. I would replace it and start with a new warranty.
Mar 20, 2008 | Canon ImageClass MF5770 Laser Copier...
HP Officejet 6310 All-In-One InkJet Printer Logo
12 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
