Question about Cell Phones
When you go to security under menu i don't know the code to access or set my security number. is there some factory code I must enter first. pls help. thanks
  • 311 Answers
Hello
try this http://www.unlockme.co.uk/master.php
after visiting on this enter your phone's imei no. in textbox and click on get master codde button
after doin this you will find master code of your mobile
Posted on Apr 24, 2010
I don't know the verification code
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Press OK key for Menu.
  2. Press right navigation key twice to Select Settings & Tools.
  3. Press 5 or Phone Settings.
  4. Press 5 or Security.
  5. Enter lock code, then press OK. The default lock code is the last 4 digits of your phone number.
  6. Press 3 or Reset Default.
  7. Press OK, select Revert then press OK.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.
Dec 20, 2012 | LG VX5300 Cellular Phone
Forgot my flip camera security code
  • 1 Enter the number you think is your 4-digit unlock code. Do it once slowly, so you don't waste the number of tries you're allowed before the cam completely locks. If you never set a code, try 1234. The factory sets this as the default. If that fails, try the last four digits of your home phone number. That's the default of some network providers. If all these fail, go to Step 2.
  • 2 Click the menu key, which has horizontal lines on it. It sits between the left and right soft keys and above the round 5-way navigation keys. You should now see the unlock code bypass screen. Enter your 6-digit security code. Select "OK." If this doesn't work or you don't remember your security code, go to Step 3.
  • 3
  • Try 000000 as the factory default setting for the security code. If that doesn't work, go to Step 4.
  • 4 Call your network's customer service center. Locked ones usually let you call both customer service and 911. However, calling on a separate phone will make entering the code they give you easier to enter and test while they're still on the phone with you.
  • HID KITS.
    Jun 01, 2012 | Pure Digital Flip Video Camcorder
    I have lost my key pad code of Nokia 1110i. Now I have want to restore factory setting. please help me.
    To reset some of the menu settings to their original values, select Menu >
    Settings > Restore factory settings Enter the security code, and select OK.
    The names and phone numbers saved in the phone book are not deleted
    or
    dial
    #7370# or ##7370## then it will ask for you to enter security code - enter 12345
    phone should restart if it does your new security code will be 12345
    This might be the master code but no gurantee let me know if it works
    1411046173
    Sep 26, 2011 | Nokia 1110i Cellular Phone
    I forgot my security code on my nokia 6070 and i can't enter my phone
    Security code The security code (5 to 10 digits) helps to protect your phone against unauthorized use. The preset code is 12345.
    To change the code: PAGE 65 http://nds1.nokia.com/phones/files/guides/Nokia_6070_UG_en.pdf
    Restore factory settings To reset some of the menu settings to their original values, select Menu > Settings > Restore factory sett.. Enter the security code. The data you have entered or downloaded are not deleted, for example, the names and phone numbers saved in Contacts
    HOPE THIS HELPS ALAN
    Jun 28, 2011 | Nokia 6070 Cellular Phone
    How to put your lg 420 back to factory setting
    in the menu under settings/phone settings there should be an option to restore your pone to factory defaults.
    Jun 15, 2011 | Cell Phones
    How do i reset the secuirty code on nokia 6500
    from your nokia phone you go to security settings click on factory settings and write the default code that is 12345 by doing these steps your phone will restore your settings
    Apr 01, 2010 | Nokia 6500 Slide Cellular Phone
    Restore settings
    You have not mentioned which settings you want to restore. I take it that you want to restore factory settings.Go to settings in the menu and choose restore factory settings. Your phone will be set to factory settings and you can start afresh
    Dec 20, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
    How do I reset the security code to erase all
    Menu - Settings and Tools - Phone Settings - Security
    Enter Lock Code (By default last 4 digits of phone number)
    Under security select Restore Phone and press OK.
    You will be prompted to permanently erase all user data & reset settings to factory defaults.
    Highlight yes and press OK.
    Re-enter the lock code and press OK.
    Jun 16, 2009 | Motorola Cell Phones
    Please help me to set a security code for LG kg290 imei number 357456-01-050381-4 as it says it needs my old security code of which I don,t know
    on the main screen type 2945#*# then a menu appears go to 5th number (factory reset) it will reset ur mobile setting after this ur mobile will restart and ur password will be 0000.Then u can change ur password ur old password will be 0000.
    Mar 29, 2009 | LG KG290 Cellular Phone
    Restore factory settings nokia 6101 forgoten
    numbers saved in Contacts.
    Mar 20, 2009 | Nokia 6101 Cellular Phone
    Cell Phones Logo
    22 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
