Question about Frigidaire GLTF2940ES Front Load Washer
We have a frigidaire gltf1670 aso washer and it will not spin when it reaches spin cycle. What would cause this problem?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
Frigidaire front loading washer has loud spin cycle, Why?
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
Mar 11, 2015 | Frigidaire GLTF2940ES Front Load Washer
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Where is the motor coupler on a Frigidaire front loader washer model no.gitr1670 aso.
Hey friend, thank you for your inquiry!
Based off the information you have provided I was unable to locate the motor coupler but I was able to locate the parts manual which provides every component available within your Frigidaire washer. I hope this is beneficial to you. -Matt
Frigidaire Manual Search Results
Oct 08, 2014 | Frigidaire Washing Machines
I have a Frigidaire washer 2003 model no. gitr 1670 aso front loader that will not wash or spin. Everything else works like fill with water and water drains.
Hi friend, thanks for your post!
I see that your Frigidaire washer is not washing or spinning but everything else is working properly. I would advise you to check over the drain hose, make sure it is not restricted or too far down the drain pipe. If that checks out it could be a possible problem with your motor or control panel. One of those components could need to be replaced and for proper replacement I would recommend assistance from a technician to have a proper diagnosis completed. I hope this is helpful. -Matt
Oct 08, 2014 | Frigidaire GLTF1670A Front Load Washer
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
The clothes are soaking wet after final spin in our Frigidaire GLFT2940ES1 front load washer
Good Morning Todd, thank you for your inquiry!
Often when clothing continues to stay wet, it is because your washer may not be reaching full speed during spinning cycle or not spinning long enough. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. Please wait roughly ten minutes and then turn your washer on. Select a normal cycle, allow cycle to complete and if resetting the power does not correct the issue you may wish to reach out to a professional who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Nov 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle
sounds like a faulty timer unit.
Aug 26, 2013 | Frigidaire ATF6000ES Front Load Washer
ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Aug 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
275 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
