Question about John Deere Tractor 1020, 1520, 1530, ITJD37
Tune up on 3 cyl. gas engine for a jd 1020
Need gaps for plugs and points
2 Suggested Answers
SOURCE: I have a 1965 0r 66 1020 3 cyl gas engine. It
I have a JD 3 cylinder gas 1520 that had a very similar sounding problem. Turned out to be a clogged fuel filter inside the connection of the fuel line to the carb. An old time JD mechanic fixed it for me the first time and I have since cleaned it again after a dry dusty mowing season. I hope this helps.
Posted on Oct 26, 2010
What is gap
Hi, Mike pertaining to engine spark plugs, "GAP" is the distance between the positive and negative electrodes at the base of the plug and is measured in thousands of an inch or mm by using a round pin gap gauge or flat blade feeler gauge. Every engine manufacturer has a specific design-size-heat range- gapped spark plug. Gaps will vary depending on engine brand. Gap is also referred to in engines using a mechanical "POINTS" ignition system instead of electronic ignition (what is the points gap) for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
How to Inspect and Adjust the Spark Plug Gap NGK BOSCH CHAMPION N3 DENSO
http://www.jsesc.com/mfg_docs/ste/Spark_Plug_Application.pdf
Points and Condenser Setup wiring Setting Gap Cleaning Points Setting...
Multi Ground Spark Plugs NGK Spark Plugs Tech Video
Mar 12, 2016 | Motorcycles
Spark plug gap settings chart and points gap
What make of motor and horsepower,plugs normally 25thou inches.evinrude Johnson below 40hp points 20thou inches,55hp and up 10thou.to take flywheel off you need a puller
Aug 24, 2014 | Boating
1968 Ford Ranchero
Spark Plug Gap is .032 inch. Many have started using .035 as it is easier to set using most newer tools.
Point Gap is .016 inch. You may also set point gap by using a dwell meter if you have one. That setting would be 32 degrees.
Aug 01, 2014 | Lisle 67870 Spark Plug Gauge Gap
Points gap 305 smal block
Set your points gap using a dwell meter - 30 degrees (range 28 to 32 degrees). Spark plug gap .035"
Jul 13, 2014 | Chevrolet Chevy Cars & Trucks
Gape setting for points on massey fergson 135 gas motor ?
need spark plug gap and point gap for MF 135
I found this link about the points gap and plug gap.
"My I&T manual says .021 point gap and .025 plug gap."
There's a lot more information on the MF 135 on the web. Just do a search ' MF 135"; "massey ferguson 135 perkins gas engine point gap"
Jun 14, 2014 | Computers & Internet
Point gap 66 dodge 383
Considering its power and fuel economy, I'd go w the std plug gap is .035" to start & maybe experiment w .040". The std point gap is .016" & you might experiment w tightening that up a bit which will increase your dwell (more coil saturation time & a hotter spark) at the expense of shorter point life because they are closed longer & current is flowing thru them for a longer period of time but you are switching over soon. that might give you more gain than diff plug gaps.
Mar 30, 2013 | Cars & Trucks
Vw caddy rabbit 1.6 point gap spark plug gap?
Most point gaps are between .003 and .005 I would try a plug gap of 0.030 to start. I would be happy to give you exacts if you provide a year make and model.
Mar 18, 2013 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
1981 converted to points, whats the point gap? and and the spark plug type and gap?
Point gap is about .018" if you can get the
timing aligned there. If not, vary the gap
slightly.
Spark plug is NGK BPR5ES-11 with a .022"-.025" gap.
Electronic ignition plug gap is much larger at .040"
Aug 20, 2009 | Harley Davidson FXDWG Dyna Wide Glide...
Ignition point gap and spark plug gap inboard outboard omc
.019 for the points and .035 for the plugs
Jul 05, 2009 | Boating
John Deere Tractor 1020, 1520, 1530, ITJD37 Logo
447 people viewed this question
Top John Deere Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
john h
Are you a John Deere Toy Expert? Answer questions, earn points and help others
