Question about Sony PlayStation Portable (PSP) Console
Answer? did you ever find out how to get the lcd screen to work?
  • 31 Answers
What kind of wuestion is that can you be more precice please
Posted on Mar 28, 2008
SOURCE:
I need both screens for rca Galileo 11 pro lcd and touch screen
Answer 1:
From your description, the LCD is cracked. The outer glass you described is the touch screen digitizer and it sounds as though this is intact. If it was broken, even with the LCD visibly cracked, you would see that it was also broken. A similar question was asked in the forum titled, How do I replace a cracked screen?
In reviewing that post, the first answer indicates that the digitizer can be replaced independently from the LCD. Upon doing a search on Amazon for the LCD itself, I did find one listing that you could use to purchase it separately. However, the disassembly video in that post was focused on replacing the digitizer.
I found a similar video on Youtube, titled RCA 10" Screen Replacment - Disassembly - RCT6203W46 PRO, which may be more relevant to start from the back and work your way to the LCD. This video goes as far as replacing the digitizer, but you'll just need to remove the LCD and the respective connections and attach the appropriate ones to the new LCD.
Furthermore, I did a search on eBay and discovered that there are two versions of the LCD. One that is a straight lcd cable and the other that uses an l-shaped cable. It is important to purchase the correct one. This ebay listing is specifically for the straight cable, but the seller also sells the l-shaped cable as well.
How do you know which one your tablet has? You may need to disassemble it to find out, as there was no specific documentation that I came across based on the model number or manufacturing date that indicated a specific way to know. You could try contacting RCA support, but disassembling helps confirm it before you decide to order from eBay, Amazon or any other third party.
Answer 2:
https://www.google.com/search?q=I+need+both+screens+for+rca+Galileo+11+pro+lcd+and+touch+screen%3F&rlz=1C2GIGM_enUS766US766&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwi6rqjt6IXXAhWKQCYKHUNvBNcQsxgIKA
Oct 22, 2017 | RCA Computers & Internet
The touch screen on my iphone 6
To know if the phone is working, turn the ringer switch on & off. You should feel the phone vibrate.
It could be a battery issue too? Does the screen bulge up a bit in the center? If yes the battery needs relaplacing ASAP if not sooner, otherwise it will break the screen & possibly stuff the phone as well if battery leaks into the phone
May 03, 2016 | Apple iPhone 6
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
Will a replacement screen for an acer aspire part #5733-6607 work in an emachines e525 series
https://www.laptopscreen.com/English/model/Acer/ASPIRE%205733-6607/
http://www.lcdscreen.com/eMachinesModel_eMachines_E525.htm
First of all the eMachines E525 has to use LED backlighting.
Does it?
If so there is one requirement that is crossed off.
No? Then the answer is No.
Next, you really need to look at the manufacturer ID info on the back of the Acer's LCD screen, and the same info on the back of the eMachines LCD screen, to be SURE.
Example,
http://www.insidemylaptop.com/replace-screen-on-acer-aspire-4830-series-laptop/
Scroll down to the bottom of the page, look at the last photo.
THAT, manufacturer information.
'Armed' with the Acer's LCD screen manufacturer info, then check to see what all laptops it will work on.
And/or if it works on the E525.
THIS, is the theory.............
The LCD screen of course, isn't manufactured by Acer.
Neither is the eMachines LCD screen.
(In fact the Acer laptop isn't made by them.
Neither is the eMachines.
One of three main companies made it for them.
Quanta Computer, Compal Electronics, or Wistron Corporation)
LG, Hitachi, Sharp, NEC, Chi-Mei, HannStar, Philips, and Samsung; are just a few LCD screen manufacturers for laptops.
If you give me the Acer LCD screen manufacturer into, and the eMachines LCD screen manufacturer into, let me see if I can find out.
Post back in a Comment.
http://www.youtube.com/watch?v=G2zGopPM7AM
http://www.youtube.com/watch?v=16zVct3M13E
Regards,
joecoolvette
Feb 27, 2013 | eMachines Computers & Internet
How to fix scratches on lcd tv screens what is the best way to fix scratches on a sony kdl52xbr6 tv screen or do I contact Sony directly
If there deep scratches you need to replace the outter layer and that could get expensive. Now if there small scratches a lcd repair kit would work. You can get those on line for the fraction of the replacment of the lcd screen.
thanks
please do leave feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 03, 2010 | Sony BRAVIA KDL-52XBR6 LCD TV
Replace Garmin nuvi 255 LCD screen
If the touch screen is working well,then you only need to buy the LCD sreen,but usually suppliers will send the LCD with touch screen as they are one whole part.you can try to contact :
[email protected] for further information about it.
Nov 14, 2009 | Garmin nuvi 255W GPS Receiver
LCD screen don't work all the time
pls see the link
Flex Cable might be damaged u will get all instructions and answer on this page u can do it urself it is a frequent fault in screens that have twist function \
Pls rate me WELL !
See this link for Repair Instructions
Apr 14, 2009 | Canon PowerShot SX10 IS Digital Camera
Vertical black line on a LCD screen
LCD screens do not work the same as CRT tvs no vertical output IC, you have a screen fault which would need the screen replacing
Oct 09, 2017 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Lcd scrren blank on 4 month old nikon s200 coolpix
Sounds like Nikon are just trying to get out of fixing it.
Have you read the terms of the warranty. If the screen is not working then it is more than likely an electronic fault and they are covered by the warranty. The only way the screen would not be covered is if it was damaged by the owner. The screen is part of the camera and therefore comes under the warranty, unless it specifically states that it is not covered in the warranty. Ask a consumer rights department. Don't take no for an answer.
Mar 06, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
