Scepter I accidentally hit the accept button but my problem is not fixed. it's being used as a tv So I tried Component Cables and Composite cables (I've never used the VGA cables on it). No change. The back light comes on, the Scepter logo comes on, then goes away, the screen remains black, but the back light stays on. I tried several different sources. ie: DVD player, PS3, satellite. Thinking it may be the connector (where it is soldered to the board, I also tried the composite plugs on the side, to no avail. Oh also the OSD doent work, Can't change channels volume source.would it be a problem with the inverter board? is there a way to test the inverter?
  • Preacher
    Preacher Mar 25, 2008
    I'm pretty sure it's the power supply. I would almost bet it is a dielectric capacitor problem in the power supply. It worked fine for a while almost 2 years than it just went out. When you turn it on, the backlight comes on, the sceptre logo comes on, then fades away, tnen the screen stays black. the power light stays blue, the backlight stays on too. but i have no picture or sound. As far as I have been able to figure out, no picture with sound would be the inverter, no picture with no sound would be the powersupply, and the way they put these caps right next to the heat sink, i would bet that they are the cause.
    Sergeant:
  • 406 Answers
Please let me know the problem in detail.
Posted on Mar 24, 2008
With the use of rca/video cables and the Samsung composite cable, how do I connect to an audio/video receiver(surround sound)
There are alot of different options when it comes to your connection basically , it comes down to quality and what in and out jacks are available to use. To me 'composite cables" were always the red, white, yellow combo where, yellow is video and red and white are l/r sound. "Component cables" were always red blue and green. The component cable provides a higher quality picture but, does not carry sound, like composite. To gain sound using component cables, you have to add either your yellow composite or a digital optical cable, again, depending on what your system will accept. HDMI carries both audio and video at the best quality and is easy. To answer the question for what you have if you have "composite"(red, blue,green) this will provide the best picture but, you will have to use the red and white "composite" for sound.
Mar 25, 2011 | Audio Players & Recorders
When I plug my PS2 or VCR into the back of my TV using red, white (audio), and yellow (Video) cables, the picture is grey and fuzzy. I have plugged the yellow into the far left port marked "Y". I...
Yellow is a composite output and should be plugged into a composite input, whereas Y indicates the COMPONENT input of the TV. If you don't have a separate composite input use a scart to phono (rca) adapter in your tv's scart input.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 04, 2011 | Insignia 42" LCD Flat-Panel HDTV
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Jan 22, 2011 | Nintendo Wii Console
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have a samsung led tv and am trying to hook up a wii. The tv does not have component video - only hdmi and usb. How do I hook this up?
I've never heard of a TV not having component cables (the 5 plug cables: red, blue and green video cables, red and white audio cables). I've seen some newer ones without composite (3 cables: yellow video, red and white audio), but never component.
I find is hard to believe it has no component. I looked at some Samsung LED tv's this weekend, and although they lacked composite, they had component. Are you sure you mean component?
The Wii only comes with composite video cables, so you'll need to buy a component video cable for the Wii to hook it up if your TV has no composite inputs.
Component Cables for the Wii
TV's have inputs on the side and rear. If the TV truly has HDMI, USB and nothing else (which I find hard to believe), then you'll need a cheap home theather 5.1 receiver. Ifyou get a cheap one with HDMI out, it should have a few composite inputs on the backside. A cheap sony one can be had for sub $200. If you hook the Wii into the receiver via composite, and the receiver into the TV via HDMI, it will allow you to hook up and play the Wii (and it may upconvert it too, depending on the receiver).
Nov 23, 2009 | Nintendo Wii Console
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Rca sound system hooked up to the tv the dvd pictures is black and white
I see three possible problemos:
1: You are using a composite connection and your tv is downright crappy at displaying a composite feed--I know mine is. Try upgrading to component if your tv supports it. If not use a s-video connection.
2: You are using an s-video connection and there is some connection problem, either in the DVD player, the cable connectors, the cable itself, or the s-video input on your tv. Upgrade to component if your tv supports it, otherwise try the cable and DVD player out on another tv to see if the tv is the problem, or use the cable on a different DVD player to see if the cable is the problem.
3: You are using component input only two of the cables are loose OR you are only using the green-colored cable. Either plug in all three component cables (red, green, blue) or try pressing the cables in while watching to see if that fixes it. You may need a better cable, some of them are crappy at staying in.
Apr 06, 2008 | Televison & Video
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Electro Med Services...
