Question about Maytag PYE2300AY Electric Dryer
Dryer model is PYE2300AYW Approx 5 yrs old--no troubles before; clean filter every time but it's in a bathroom with the back in an enclosed closet. When i pulled away the wooden piece covering the back, I found a lot of lint buildup but the plug, hoses and venting intact. It had been working normally until it just stopped--and now it just won't start. I suspect a fuse might be out, but it's purely a guess. I hope it's something like a quick fix, but am not sure. It will be a huge challenge to move it out of it's location, but I need to get it going again. Any advice?
  • yellatcs2 Apr 23, 2010
    Thanks, I'll check this out. If I have more questions, I'll get back to this site.
  • Maytag Master
  • 19,396 Answers
Hi.
Replace the thermal fuse in the heater assembly. Here the part.
When there is too much lint, this cause overheating, and the fuse is the first part to blow.
The thermal fuse is only $3 or so, but if you want to test the fuse before replacement you can use a multimeter set on Ohms. If the fuse has blown, the multimeter will read infinite impedance on the fuse contacts.
Regards.
Posted on Apr 23, 2010
  • Ginko
    Ginko Apr 23, 2010
    Hi.
    Please test or replace the fuse, if the dryer still does not work I will tell you how to check the rest.
    Regards.
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Oct 13, 2010 | Whirlpool LEQ9858P Electric Dryer
Dryer model # ALE866SAW approx 9 years old ran great until tonight. Went to touch up load of whites (socks underwear etc) and get a sound from the back that sounds like an electric motor that just went on...
Yes it sounds like the motor is bad and that is very fixable, but what about the belts the guides and the wiring??? If this has been used hard ( more then 6-8 loads a week for 9 yrs then I would go new...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 09, 2010 | Dryers
Maytag dryer model PYE2300AYW dryer runs gets hot stops. when I try to turn it back on it makes a noise and won't start back up. What could be wrong?
It sounds like your motor is bad. you could take the dryer apart and clean off the lint on the motor and see if that helps but it sounds like i said the motor is faulty.
Mar 24, 2010 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer model pye2300ayw, what should the ohms reading be on the thermal fuse?
doesn't matter,it's either good or bad,when you touch the meter to it if it reads 1 and doen't move it's bad if you get any reading it's good,if the dryer is loaded with lint in the duct that the lint filter slides into and the vent line is blocked it will keep popping on you, clean out the dryer,number one cause for popping the thermal fuse
Feb 22, 2010 | Maytag Dryers
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
I have a trouble code 11 on my Rinnai model 2532 water heater which indicates no ignition. I checked for gas supply by turning the furnace on which is approx. 1 ft. away, it works. The water heater is...
11 is a ignition failure code. Could be alot of things, I suggest calling a tech who has repaired these before. Pull the front cover off and have a helper turn on a hot water faucet. Look thru the viewing window to see if the unit is firing then going out. If not, clean out the water filter on the inlet side of the plumbing. You will need to turn off the water supply prior to cleaning it. If the unit fires but shuts off seconds after ignition, you may have a dirty or bad sensor. Call a proffessional at this point. Sorry
Oct 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How do I change a drive belt on maytag model pye2300ayw
remove the back inspection panel, take the old belt off and put the new one over the series of pulleys and tensioners as you took it off, about 15 minutes work
Aug 15, 2009 | Maytag PYE4558A Electric Dryer
How to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
27 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
