Question about Brother MFC 7840W Printer
Brother MFC7840W How to replace the pickup rollers
Brother MFC7840W How to replace the Doc feed pickup rollers.
Doc feeder fails to draw pages through consistently, so I found a distributer of the feeder rollers. Bought the rollers but have determined that I don't know how to do the replacement. Help?
Soulvisitor
  • 1113 Answers
SOURCE: Brother DCP8020D Document Feeder
Clean rubber rollers with metho, run a page by hand of laminate or stiff card threw the doc feeder. Stick it where the paper comes out of DF and ensure path is clear.
Push down on left side or tape down little black switch (rear left corner near glass)while trying to use df to confirm hinge aint the issue
If it is the rollers it should feed when paper is "helped a little" with hand at feed time
Ensure prints ok when using glass instead of df to know it is df problem
Cheers
Posted on May 08, 2008
SOURCE: Document Feeder jams
I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
Posted on Feb 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: printer wont load paper. there is a rattling noise and upon restarting it says Doc. feeder Jam
Follow these instructions to clear the jam and replace the jam clearance component.
For the noise issue, see here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 22, 2009
nalin_elliot
  • 224 Answers
SOURCE: automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
Posted on May 30, 2009
ramon_jleme
  • 94 Answers
SOURCE: Need to replace pickup roller on MFC-7820n.
Well, how to do that I don't know how to explain you, but first of all try to clean it, do it with thinner, this may solve your problem for while, at least until you find a way to remove and change.
Posted on Aug 14, 2009
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
Need replacement process for paper feed roller in scanner compartment.
On the doc feeder there are 2 arms that go down into the machine. UNPLUG machine first. You squeeze them carefully and rock the doc feeder backward. It may take some manuevering,
Once you have separated the top half of doc feeder, you will see a wire harness going into the upper half, CAREFULLY unplug it. There are several screws holding down the cover over the bottom half, remove them and again carefully separate this cover from the main body.
Once this is done you should be able to replace the feed roller. One note, while you have it this far apart you ought to change the separaetor pad in the top half.
If this helps you, please log in a vote for me, thanx
Feb 07, 2011 | Brother Fax-1360 Plain Paper Inkjet Fax
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
Doc Feed Problem
I would replace the Pick-up roller, Feed Belt, Sepearation roller, and torx Limiter for starters IF you cannot replace them, Clean them with warm water and soap, let them dry, and try the doc feeder, Most Multi feed problems are Torx limiter or clutch problems.
Apr 11, 2009 | Office Equipment & Supplies
Brother IntelliFAX 4100 pickup roller
Need more info. Do you need help in replacing the roller? If so, it is a big job. You have to completely remove the doc feed asm and all covers to get to the roller shaft asm. Best to let a tech do it for you.
Have you tried cleaning it with some roller cleaner. Try a little bit of Goof-Off cleaner on a cotton rag.
Aug 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Xerox WorkCentre XD105f auto doc feed fails. The roller does not descend far enough to contact the page being fed
There is a spring wound clutch that is slipping in the doc feeder.
You can try cleaning it or google a place called The Parts Drop.
Call and ask for Britt he can help you with ordering the right part at a fair price.
Jul 05, 2008 | Xerox Office Equipment & Supplies
Cheers
Apr 28, 2008 | Brother DCP-8020D All-In-One Laser Printer
Feeder
Paper being printed or Sent? but prob Dirty feed roller (paper feed or doc feed roller)
Oct 11, 2007 | Brother MFC-8220 Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Brother MFC 7840W Printer Logo
172 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
