Question about HP Photosmart C7180 All-In-One InkJet Printer
My HP C7180 all in one printer won't print colors properly. I just replaced the black ink cartridge and it prints out blue. What should I do?
gaya79
  • 31 Answers
SOURCE: No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Posted on Nov 06, 2007
  • 27 Answers
SOURCE: HP Photosmart 8450 Ink Level Indicator
replace the ink cartridges
Posted on May 31, 2008
SOURCE: Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Posted on Oct 13, 2008
patemi
  • 366 Answers
SOURCE: hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
Posted on Feb 09, 2009
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
HP ink jet 1200..prints only test page after replacing the yellow cartridge.test page only shows black and blue inks are good.need help.
Important thing: HP inkjet printers having self align technology & its aligns automatically after replacing the ink cartridge/s.In the process of align it will prints align page &it will read it on the model.
Suppose if you replaced yellow cartridge, as usually it will print align page, but if one or more cartridges not printing properly align will not completes. Results every time it will prints the align page when its switching on. Align will completes only when all cartridges/print heads are in healthy condition.. Check the alignpage find out which colors are not printing properly, replace it to over come from this issue. Now you decide what to do?..
Dec 11, 2012 | HP Inkjet 1200dn Printer
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My hp C7180 all in one printer told me I needed to replace an ink cartridge as it would not print in color. I replace the one it said, still did not work, I have replaced all the cartidges and it is still...
First perform an observation of the printers compartibilty to color printing. For example, the printer ought to have been manufactured to capture color pixles to provide resource request in multimedia. usually is possible to have one printer that has several ink location areas to either install color media or dark ink media. In situations where a printer was designed to be black and white ink document compartible would least produce results on color when ink was interchaged. Ascertain that the printer is compartible with multimedia pixel printing proir to acquirng depeltable resources from retail.
Feb 18, 2011 | Office Equipment & Supplies
Is it possible to convert this printer so it only uses black ink and it operates without the color cartridges?
The Photosmart printers work in Thermal Inkjet printing technology. This require all cartridges to be present with ink for printer to work.
You may disable the color printing feature using the printer properties, even though the color cartridge will still be in use.
Only Laser jet printers can work with Black cartridge alone.
Regards
Riztech
If this solution is helpful,kindly vote 'thumbs up' and testimonial.
Dec 31, 2010 | HP Photosmart C7180 All-In-One InkJet...
HP 7180, no reds are printing and there is blue ink inside on the printhead reails, how do i get the print head to center to look at it?
you have to click the power button and maintenance button together for 10 sec. if it doesnt work...
press the ink button for 6 sec then the cartridge should move automatically...
regarding with no red printing... try to check the cartridge(colored) you might not put it properly or there's still a seal on it thats why it cant be read by the printer. if you have check it and still not working...
you need to reset the software printer...
Mar 26, 2010 | HP Photosmart C7180 All-In-One InkJet...
Hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Nov 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Color is wrong
Have you tried replacing the cartridges? Some programs such as Adobe Reader will generate a "black" equivalent from the color cartridge. In this case, if the color cartridge is low in red, the outcome will be blue. This would signify that the color cartridge needs to be replaced. HP supplied a utility program for the HP6122 to detect and report ink levels. If you have this utility, check the levels. The utility will only work if the computer is directly connected to the printer -- not thru a print server. If you don't have the utility, you should be able to get it at the HP website http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=83028&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=88749
You might find that both the black and the color cartridges are out of ink. Some print drivers can detect when the black cartridge is empty, then attempts to print a black equivalent using the color cartridge.
Mar 16, 2009 | HP DeskJet 6122 InkJet Printer
C7180 Print in color without all cartridges
You can usually print with an empty cartridge, even though the software will inform you that the cartridge is empty. Your print quality may be affected, however.
Dec 03, 2008 | HP Photosmart C7180 All-In-One InkJet...
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
141 people viewed this question
Seeker5211
Seeker5211
