Question about Sony AA Nimh 2500 Mah Rechargeable Battery
Cylindrical are circle of radius 3.00 ft and the cylinder is 20.00 ft long. determaie the volum of depth2.00 ft. how much the volume?
V = pie x r2 x h
V= pie x 3x3x20
V=180pie
Posted on Apr 24, 2010
  • dhelvin Apr 24, 2010
    I cannot express what i want to imply in the problem just comment if ever you have a question on my solution
What is the cubic yard of a circle that is 10.82feet diameter x 16inches deep?
the formula for volume of a cylinder is Volume = pi × r2 × h
but if you arent math savvy, first you convert your units so they are the same. all you have to do is change 16 inches into 1.3 feet and divide your diameter (10.82 feet) by 2 to give you the radius (5.41 feet)
plug in those values here:
https://www.bing.com/search?FORM=U312DF&PC=U312&q=volume+of+a+cylinder
and you will get 119.5 cubic feet
then convert cubic feet to cubic yards here:
http://www.metric-conversions.org/volume/cubic-feet-to-cubic-yards.htm
and the answer to your question is 4.425 cubic yards
Apr 26, 2017 | The Office Equipment & Supplies
Calculating pond capacity using volume of a cylinder in gallons?
the formula to calculate volume is surface are multiplied by the height ( depth)
that is PYE times the radius squared multiplied by the depth of the pond
1 cubic ft of volume = 7.48 gallons
Mar 28, 2017 | In Office Equipment & Supplies
What formula do you use to calculate cylinder volumes
Volumes are any three dimensional measurement...
I Seriously doubt that I could get Pi ("pie") to print...
But I'll just GIVE YOU the number (much simpler)
Pi = 3.14159
Inches, feet, yards or meters.. all the dimensions need to be in the same values... So if you have an inch "ruler"...
That is just fine...!!
Your first step would be to determine the diameter of the inside of your cylinder in inches...
CONVERT that to the RADIUS by DIVIDING by 2...
Multiply that RADIUS by itself and then by 3.1416 = area of circle in INCHES... (radius "squared" x Pi = (square inched)
Then MULTIPLY the height (in inched) by the AREA...
EQUALS THE VOLUME in CUBIC INCHES...!!
But I'll just GIVE YOU a REFERENCE (much simpler)
mathematical constant ?
Area of circle
Feb 18, 2017 | Office Equipment & Supplies
How many cubic yards would it take to fill in. 20' x 2' diameter
Hi Paula:
A mathematical logic question.
You need to get all of the measurements in the same units.
- A cubic yard is 1 yard x 1 yard x 1 yard
- equals 3 ft x 3 ft x 3 ft
- equals 27 cubic feet,
so once you have the volume of the pipe in cubic feet, you divide by 27 to get the volume in cubic yards.
- Volume of a cylinder (the pipe) is the cross sectional area X length.
- Area equals Pi x r squared.
- equals 22/7 x 1 x 1
equals 3.14#####
times length (20)
equals 62.857### cubic feet volume
divide by 27 cubic feet
equals 2.328### cubic yards.
- The answer is always the easy part.
- what is important is knowing exactly what the question is, and
- determing what calculations are needed to get the answer.
Wasn't that better than if I'd just said 2 1/3 cubic yards?
Cheers
Jan 05, 2016 | Office Equipment & Supplies
Find the volume of a cylinder the radius is 8cm the height is 6cm what is the volume
Volume of right cylinder is
V=(Area of base)*height.
If cylinder is circular Area of base =PI*radius^2=Pi*r^2
Volume is V=Pi*(8^2)*6 cm^2
Finish the calculation.
Jun 28, 2014 | Office Equipment & Supplies
Volume of a cylinder formula
Volume of a right circular cylinder of radius r and height h is
V=PI*(r^2)*h
Figure out which is the radius and which is the height, then plug in the formula above. Result is in cm^3
Jun 26, 2014 | Office Equipment & Supplies
What is the capacity of a cylindrical beaker with a radius of 5 cm and a height of 15 cm?
The formula for volume of a cylinder is
f4158dab7968d0898a95f83495604c73.pngso, the volume of your stated beaker is 1178.097225 cubic centimeters.
Mar 07, 2011 | Computers & Internet
If a lead pipe 1/4in.thick has an inner diameter of 1/2in.,find the number of cubic inches of lead in a pipe 10ft.long
A pipe can be seen as two cylinders, one of "air" sitting inside the other, in this case lead.
To get the volume of a pipe you thus subtract the volume of the "air" cylinder from that of the lead cylinder.
Volume of a cylinder = area of circular cross section (or pi times square of the radius) times the height (or length) => ? * r2 * h
Volume of a pipe = Volume of cylinder 1 (outer diameter) - volume of cylinder 2 (inner diameter).
In this case; Volume of outer cylinder => inner diameter 1/2" (0.5") + pipe thickness 1/4" (0.25") = 3/4" (0.75") divided by 2 to get radius = 0.375".
3.14 (?) * 0.375 * 0.375 * 120(10 feet) = 53.01438 in3
Volume of inner cylinder => inner diameter 1/2" (0.5") divided by 2 to get radius = 0.25".
3.14 (?) * 0.25 * 0.25 * 120(10 feet) = 23.56194 in3
Volume of lead in this pipe = 53.01438 - 23.56194 = 29.45244 in3
Hope this helps ;)
Jan 27, 2011 | Computers & Internet
Which would require more steel, acubical beam wit a length of 25ft, a width of 2 ft, and a height of 3ft or a cylindrical column with a height of 10ft and a radius of 2ft
Well if you go off of the volume, which is how much an item is made of versus how much space it takes up which is area, for the cubed beam you let 150 cubic feet versus the cylinder which is 125.6 cubic feet. The cylinder uses less product.
May 17, 2010 | Plumbing
Sony AA Nimh 2500 Mah Rechargeable Battery Logo
61 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
