Question about Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier
Ionic breeze smells like a serious electrical short when I turn it on.
Usually this type of smell is associated with dust and debree collected on the plates.
Just give it a good wipe down with a dry cloth and it should run like new again.
These units will run well for many years if they are kept clean. If you are in a dusty enviroment, you will need to clean more often.
I have owned these for years and have not had any major problems. They will start acting up when the system becomes dirty.
A few years back I bought several of these that supposidly were defective. They were filthy on the inside, once cleaned they worked perfect again. I gave them out to family and they all have worked perfect since.
These units take alot of heat on the blogs, but I say it is mostly hogwash from competitors. Just clean them and you will be happy again.
Don't believe Consumer reports they are a joke, they will write negative columns based on inexperienced and uncontrolled testing.
The ionic breeze does work, there are no allergy sufferes in our house since we started using them years ago. Even our Bulldogs enjoy the benifits of these!
Posted on Dec 24, 2010
  • 59 Answers
THEY RUN WITH A DIFFERENT KIND OF SMELL PEOPLE ARE NOT USED TO. ITS A HIGH VOLTAGE SCARY SMELL .IF IT SEEMS TO WORK OK THAN IT MIGHT BE OK
Posted on Apr 24, 2010
I have 2 ionic breeze quadras and the fans will not keep running. My husband smokes alot I was wondering if maybe the tar from the smoke made them sticky or something. What can I do to fix them? Thanks,...
They don't have fans. They attract things using an electricity. if you put your face in front of it you should be able to feel a light amount of air moving and smell what i describe as fresh air. if so it's working fine.
Jan 24, 2011 | Sharper Image Ionic Breeze Quadra Air...
My ionic breeze quadra air purifier keeps turning on and off. I have cleaned the fins, what else can i do?
Hi.
The filter will probably need replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. Parts are also not distributed anymore.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 08, 2010 | Sharper Image Professional Plus Ionic...
My Quadra Ionic Breeze, has a small glowing fire within it at the base. There is a smell of plastic/electric burn. Though the odor did cover the odors in my house, I think I have a fire hazzard on my...
the ionic breeze uses high voltage to move/filter air .. if the insulators break down there will be an arc such as what you see .. there is a way to dig out the carbonized material and seal it with materials that can handle the high voltage but any repairs are costly .. its unlikely you can repair it for less than a new conventional filter .. the ionic breeze was unique and expensive but didn't move a lot of air ..it was quiet but often produced some ozone .. long exposure to ozone is not a good thing .. here is a site where you can learn more about your unit
http://en.wikipedia.org/wiki/Air_ioniser
check out where it says "Consumer Reports court case" ... that said, the electrostatic concept does probably remove small particles that are hard to do with conventional filters .. the arcing you see in your unit is indeed not safe . ... here is more that you likely don't want to hear..
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
in the next one look down where it says "Ionic breeze" under "helpful information" that will frost the cake
http://www.sharperimage.com/Pages/Helpful+Information/#ionic_breeze
i am sorry to say that your expensive ionic breeze is not safe and not repairable.
Aug 15, 2010 | Sharper Image Professional Plus Ionic...
My ionic breeze s1867 turns on and off will not stay on
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Mar 02, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
I have Ionic Breeze SI730. Won't turn on.
You could try some appliance repair shops. If you are able to solder the loosen wire , do so. but the ball-baering coming offf indicates a serious problem within the motor. Look in your yellow-pages for electric motor service. They could help replacing the baearing. But do not be surprised if you didn't get the bearing replaced. Those small appliances are meant for "disposable" use.
Oct 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze Repair
Ionic Breeze GP. Unit was working. Removed insert to clean. Now the unit will not turn on.
Jun 11, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Sharper Image S1737 Shorting
Sharper Image Ionic Breeze products are no longer supported because they were proven to be ineffective by Consumer Reports causing legal disputes that the company lost. This legal dispute put the company out of business.
Here is an article about Sharper Image
Here is an article from the EPA about Ionizers
The Consumer Products Safety commission is going to release a report on all ionizers by the end of the year. Their decision could make ionizers a thing of the past.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI720 Air...
Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier Logo
343 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
