Question about Kenmore 75101 Wall/Window Air Conditioner
Cannot find vent control lever - Kenmore 75101 Wall/Window Air Conditioner
I too cannot find the Vent Control Lever for my Kenmore 580.kenmore air conditioner model number is: 580.75251800. I DO see in the owners manual WHERE the lever should be, however, I do NOT see the vent control lever, nor ostesibly WHERE the vent can be, bought the unit new in 2009 from SEARS, anyone have any ideas?
Posted on Jun 16, 2013
  • 34 Answers
If it has one and it is not broken off it will be directly below the grill that the conditioned air comes out from
Posted on Apr 24, 2010
05 malibu heater vents blowing incorrectly
The are two controls on the heater. One is the blend door and that controls hot and cool, the other is the mode selector door and that changes the place air comes from. You should be able to see those and the area that controls the air in the plenum. The plenum is behind the glove box. Open the glove box all the way and see if the controls are visible. Activate the mode control to see if the lever moves on the plenum, the problem could be anything from a broken lever, bad control, loose control, or something that fell down the defrost vents.
Feb 20, 2014 | 2006 Chevrolet Malibu
I have a 1985 F150. After seeing a pink nose poke out of one of my dash vents, I determined that I had wild life living in my truck. I have cleaned out the blower motor housing under the hood, the box...
If you had rats or some other type of wild life in your heating vents, it would be my guess that they dragged some nesting material like paper, rags, straw into your heating ductwork. Just a guess.
Oct 21, 2013 | Lincoln Cars & Trucks
Why does my 2005 explorer have no air from defrost vent, but other vents are ok
I just fixed mine. It would NOT get air to the defroster. The lever that opens and closes a door that directs the air flow to the defroster was broken. To be more specific, the plastic lever the actuator attaches to was broken. The actuator and the vacuum system were operating properly. It is simple to see but hard to get to. Remove the glove box and look up and to the left for a silver vacuum controlled actuator and arm. I was able to fabricate another lever and attach it to what was left of the OEM lever.
Oct 27, 2012 | 2005 Ford Explorer
Air only comes out defrost in all settings
I just fixed mine. The lever that opens and closes a door that directs the air flow to the defroster was broken. To be more specific, the plastic lever the actuator attaches to was broken. The actuator and the vacuum system were operating properly. It is simple to see but hard to get to. Remove the glove box and look up and to the left for a silver vacuum controlled actuator. I was able to fabricate another lever and attach it to what was left of the OEM lever.
Sep 20, 2012 | 2005 Cadillac Escalade Ext
What is the setting for the push-pull lever on the right side of my in-window air conditioner? thanks
If you want to pull fresh air into the room and not use the cooling part of the unit. pull the lever out. If you don't want to introduce fresh air into the room during the cooling cycle, push the lever in.
Thanks for choosing FixYa.
Sep 09, 2011 | Hampton Bay HBLG5004 Air Conditioner
1992 chevy g20 van ... AC blows through the lower ducts but not the mail cabin vents. What do I look for to fix this?
Behind the dash, when you throw the lever to change which vents you want air to come through, it can sometimes "slip" over little plastic gears/levers which flip the ductwork to different vents such as floor to the dash vents or defrost. look up from under the dash to see if the vent control switch is actually moving anything underthere.
Jul 02, 2010 | 1992 Chevrolet G20
The 4 wheel drive shifter is broken. How does the linkage to the transfer case come apart?
Shift Lever NOTE: Remove the shift ball only if the shift ball, boot or lever (7E067) is being replaced.
Removal
  1. Raise vehicle on hoist and position suitable safety stands under vehicle.
  1. Prior to removing the control lever assembly (7E069), be sure the shifter is in the 2H position.
  1. Loosen (do not remove) the nut retaining the shift handle (7E067) to the control lever assembly (7E069). Remove the shift handle (7E067) from the control lever assembly (7E069).
  1. Remove the vent hose (7D494) from the notch in the detent plate.
  1. Remove the control rod (7A315) from the control lever assembly (7E069). ani_caut.gif CAUTION: When removing the control rod (7A315) off the control lever assembly (7E069), do so very gently so as not to damage the control lever assembly.
  1. Loosen (do not remove) the large pivot bolt holding the control lever assembly (7E069) to the detent plate.
  1. Swing the control lever assembly (7E069) out of the way and remove the two bolts (39129-S2) retaining the detent plate to the transmission extension housing. Remove the entire control lever assembly from the vehicle.
Installation
  1. Prior to installing the control lever assembly, be sure the transfer case link (7B106) is in the 2H position (pointing upward).
  1. Install the two bolts (39129-S2) to retain the control lever assembly (7E069) to the transmission extension housing and tighten to 92-125 Nm (68-92 ft-lb). Refer to the following illustration for bolt hole application.
  1. Attach the control rod (7A315) to the control lever assembly (7E069).
  1. Tighten the large pivot bolt to 92-125 Nm (68-92 ft-lb).
  1. Attach the vent hose (7D494) into the notch in the detent plate so the white mark is flush to the outside surface of the plate.
  1. Install the shift handle (7E067) into the control lever assembly (7E069). Tighten the retaining nut to 27-38 Nm (20-28 ft-lb).
  1. Check transfer case for proper shifting and operation.
Feb 27, 2010 | 1992 Ford F250
Hot air only for defrosters and vent. Not down by your feet.
most vents are controled by vacuum canister and, a lever so; first look under the dash for the heater box and you should see a small silver can with a hose going to it this can has a rubber disk in it's middle that moves a lever slecting dash or. floor air discharge most of the time the hose has fallen off or, the lever has come off.
Apr 21, 2009 | GMC Jimmy Cars & Trucks
1986 VW Golf - blows cold air out vents
add coolant....if that doesnt work...check the thermostat...then if its not that its the water pump
Jan 14, 2009 | 1986 Volkswagen Golf
Kenmore 75101 Wall/Window Air Conditioner Logo
272 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
