Question about Arris SURFboard SB4200 Modem
Internet has stopped working.
The only led that is flashing is Power but none of the others are on?
Any way to reset the router?
Cheers,
    Brigadier General:
  • 10,406 Answers
Check that the "block Internet activity" button on the top of the router is in "active" mode, not in "standby" mode.
Unplug the AC power from the modem -- that will reset it.
Contact your ISP -- they can remotely & electrnically access the cable-modem, and will trouble-shoot, and, if necessary, will replace the modem, for free.
Posted on Apr 23, 2010
One of my TP-LINK 500Mbps has stop working .What can I do to fix it
I have to assume you are referring to TP-Link power line adapters. In any event, pick the one that is not working. Press and hold the Pair button for a second or so, the Power LED will start flashing. Wait 2 minutes, then press and hold the Pair button of your main (other) TP-Link for 1 second, the Power LED will start flashing. In about 2 minutes all should be good.
If not you may have to reload the flash software or use the disks to reset.
Cheers
Jul 13, 2017 | TP-LINK Computers & Internet
Hello. I have a Dlink dir 600 router and it worked without problems for about a year (usually there were 2-3 laptops wirellesly connected to it). Then suddenly I couldn?t connect to the internet anymore....
Make sure all the wires are connected properly. 1.-Unplug your modem and router from the power supply. Wait 1 minute. 2.-Plug your modem back to the power and wait for all the lights to stop flashing. 3.-Plug your router back to the power and wait for the lights to stop flashing
Follow these steps and your internet should be working again!
Jan 13, 2011 | D-Link DIR-600 Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
My DLink DI-604 router is not working properly. Lan port 1 I think is not working and only one computer connected to the router can connect to the internet. So I tried to remove all ethernet cables,...
Having an issue with your router or other equipment rented or purchased from Verizon Fios? Contact customer support service number 1-800-243-0019 for help. Our technical experts.
Apr 15, 2017 | D-Link (DI-711) Router
I check all connection, all wires and internet connection and the port leds lights do not light on, why?
If when you plug in the power you get the Post light flashes and then no lights you may need to do a hard reset of the router.
If you get no Post light flashes when you plug in the power then your router power supply is most likely the culprit.
Cheers,
Ron
Jan 18, 2010 | Linksys Wireless-G WRT54G Router
Billion Router Bipac 5102 flashing all the time - ADSL LED- I can not access 192.168.1.254 Mahmoud
Your router code should be 192.168.1.1 OR 192.168.0.1 This should get you to type in your user information and access your options for the router. Reset your router first by holding down the reset button for 10 seconds. Username and Password are both "Admin" If this does not work there could be a problem with your connections. Make sure everything is plugged in correctly and reset your modem as well. If it still doesn't work it is either a problem with your internet provider or your router hardware and you will have to contact the manufacturer. Cheers.
Nov 02, 2009 | Cnet CWR-854 Router
Power led solid red, internet led solid green
This is a sin of a bad unit already, first thin that you can try here is to reset the router by pressing the reset button of the device for 30 seconds , but after that and still the same light better contact your device manufacturer...
Sep 15, 2009 | Actiontec GT704WG Wireless Router...
My internet light on my router wont stop flashing
If the internet is working, then this is likely normal behaviour for your router and there is no problem. If so, cover the led's with black electric tape if it bothers you. :) (I've done this on my dsl modem)
If the web is not working, maybe reset the router by holding down the reset button for 30 seconds. If still no good, contact Belkin as the router may be dead. If a reset works, make sure to secure the router with a strong password if it's wireless.
Aug 17, 2009 | Computers & Internet
Ethernet the only light working
Reset your router .
Press reset button for 15 seconds then all settings are reset to factory defaults.
Then check let me know.
Jul 27, 2009 | Zyxel P660HW-D1 Router
D-link WBR-2310 Stop working
Sounds like a defective modem/modem failure if, it does not reset or if you take all of the other wires out and just leave the power in and none of the other lights go off then that is definitely a defective mode, I suggest either returning the modem to where you purchased it from or calling D link it should be covered under there warranty for replacement.
Nov 14, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Arris SURFboard SB4200 Modem Logo
670 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
