Question about RCA T19064 19 in. Combo
Blue Screen This T.V. has always worked. Just recently when turned on all that comes up is a blue screen. Changing the chanells does nothing. The VCR part works fine. Need some help please.
  • 476 Answers
Hello, If you are using this combo with cable and the channels just coming through, you will need to replace the tuner(mounts vertically on the main board and it's located directly behind the cable/antenna connector). If you are trying to use this TV with a set of rabbit ears, the free signal channels turnes digital last year and that is why you get nothing. The tuner as an assembly is still available from a couple of sources: Partstore.com and Union Electronics(johnl@ued.net)
Posted on Apr 23, 2010
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Apr 13, 2010 | Sanyo DS13204 TV
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Nov 20, 2008 | LG 32LB9D TV
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
I Am Having Trouble Tuning My Channels On My VCR.
Hey is the VCR set for cable? even if it's not a local channel
could try to come in. turn the blue screen off on the VCR that
might solve your problem. If the channel is weak the blue screen will come on and block it. you can turn it off by going into
your VCR settings. Also If the cable is weak a splitter will
cause this you might have to hook the cable up directly to the
VCR to record it and watch it through the VCR. that's was may
problem once.
also you can tune channel 12 to your VCR manually if it is too
weak because of a nearby local channel it won't tune in automatically.
Nov 12, 2007 | Sanyo VWM-800 VHS VCR
S-Video on the blue screen
menu has input selection to turn on/off or name video inputs.....T.
Oct 24, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Blue screen
there's a little button under the screen that turns the screen off when you shut the top look close and flip it till it comes on, they become stiff in some models and don't always pop up so with a little flip it should
Oct 06, 2007 | Durabrand DVD-1002 DVD Player
Mono setting?
What channel is it and when they tune in that channel, is the picture nice and clear or is it grainy and snowy before the screen goes blue? On some sets, if the signal is weak, the picture will go blue. This is called Blue Screen and is there so you do not see very poor, grainy and snowy pictures. Some sets will have an option in the menu to turn the blue screen off.
Aug 27, 2007 | RCA 24F512T 24" TV
Video image problem- Blue screen?
If your unit is fairly new,your VCR part might be the problem.Take it back!
If you have this unit for awhile,two things:
1. You need a professional A/V repair guy to clean up and check your VCR head.
2. The rental VHS tape is dirty.
Jul 28, 2007 | RCA DRC8335
Can't see menu to programme VCR
Try unpluging the unit from the wall for about 5 minutes then plug back in and turn it on,this will reset the brain and go back to normal.
Oct 05, 2006 | JVC HR-A592U S-VHS VCR
RCA T19064 19 in. Combo Logo
108 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
