Question about Electrolux Lux 5500 Canister Vacuum
My electrolux canister model keeps shutting off after a few minutes use. can reset by unplugging and replugging, or by opening and closing access door
5 Suggested Answers
  • 430 Answers
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Posted on Dec 17, 2009
  • 566 Answers
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Posted on Mar 01, 2009
  • 430 Answers
SOURCE: electrolux canister special edition problem
If this canister has a "bag full" light and auto shutoff, there is an internal diaphragm switch controlled by a dial on top of the vac. Set the dial for medium setting. Install a fresh bag and test again.
There is a pinhole in the throat of the vac which allows air to flow through a tube to the diaphragm. Check to see that it is not blocked with a grain of sand. There is a second pin hole in the corner of the bag chamber check there as well for blockage. If this vac is less than 20 years old the control valve for the diaphragm often cracks and needs to be replaced. You would access it by peeling ( like a banana) the soft rubber bumpers off the side of the vac and sliding the locking keys underneath the bumper out the front end of the vac when the bag door is open.Then gently popping the housing apart from FRONT to back. DO NOT try to pry the back housing off. Caution, this is normally performed on a cradle in a repair shop designed to hold all the components in place
Posted on Sep 07, 2009
SOURCE: How do you access and
How to access and replace cord winder on Electrolux Guardian vacuum cleaner
Posted on Feb 03, 2010
I am vacuuming spackle dust from sanding walls and my electrolux canister continues to open. What should I do?
Fine dust from sparkle will clog a bag or filter very quickly even though the bag is not full or even close to full. The air can't pass through the bag so it is popping the door open. Drywall dust can ruin a vacuum motor very quickly. I use a shop vac style vacuum with a cartridge filter that still clogged up after just a few minutes of vacuuming the dust but I can take the filter outside and hit it against something and use a small soft brush to clean it.
Jan 28, 2018 | Electrolux Vacuums
Where are locking keys on old electrolux canister vacuum #2100?
not sure what you mean, I assume you are trying to access the inside.Oneach side of the machine there are sliders. The long rubber deal on the sides.Theses slide out..be careful and make sure the machine is unplugged....
Jul 14, 2014 | Electrolux UltraLux 2000 Bagged Canister...
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Bag full vacuum shut off. Is there a reset
You didn't mention the model, but with several Electrolux canister models, I'd say there's probably a problem with the control valve assembly inside the canister. This would need to be repaired at an authorized Aerus Electrolux store. If unsure where the nearest store is, use this link to locate one:
http://www.aerushome.com/storelocator/
The tip on the following link covers other possible causes.
http://www.fixya.com/support/r7367127-electrolux_epic_6500_trouble_shooting
Jan 06, 2011 | Electrolux Epic 6500 Vacuum
Dec 16, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag full switch is bad
I assume this is an Electrolux Canister with long narrow body and a dial control on top for adjusting the bag fill level.. Please confirm model and name on canister, as in LE, Ambassador, Renaissance, etc.
If this is a plastic bodied unit with 2 side bumpers the body opens like a **** shell after sliding the bumpers out the front. The normal cause is a failed control valve under the dial at the top center of the vac. The failed part can only be replaced, not serviced and can purchased through an AERUS Electrolux repair center. Please confirm and I can wa;lk you through the process if required
Dec 12, 2009 | Vacuums
ELECTROLUX C101H JUST SHUT OFFWHILE WIFE WAS VACUUMING, DOES THIS HAVE AN INTERNAL THERMAL OVERLOAD SWITCH ? HOW TO OPEN UP CANISTER TO SERVICE ??
it does have an internal thermal overload device you need to put the vacuum into the shop they should be able to fix it in a few days
Aug 01, 2009 | Electrolux Guardian Bagged Canister Vacuum
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux vacuum short circuit inside the canister
Please elaborate on the problem and if it truly is a short circuit in the canister .. unplug it and provide the model number so that I can help you find the short to repair it.. Have you attempted to open the canister up and look for some evidence of the short ( carbon or burnt wire etc)? Remember to always unplug it before attempting any troubleshooting...
Sep 30, 2008 | Electrolux Vacuums
Electrolux Lux 5500 Canister Vacuum Logo
832 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
