Question about Bosch Nexxt WTMC 3300 Electric Dryer
Push start button all it does is click
Pulled dryer out and unpluged it to clean vent pluged dryer back in push start button all it does is click
  • 523 Answers
Take back off see if belt is on
Posted on Apr 25, 2010
WTA 3500 vented dryer, the drum does not spin, have cleaned the air inlet/outlets - what now?
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Oct 30, 2010 | Bosch Axxis WTA 3500 Dryer
Kenmore Dryer-90 Series- Pushed Start button nothing happened
get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
Mar 26, 2010 | Kenmore 62802 Electric Dryer
Went to push the dial in to start and it won't
first make sure you have power to the dryer.if you have power to the dryer than put your ear to the timer and see if you hear the timer running.if the timer is running than you nead to unplug the dryer and pull the dryer away from the wall so you can remove the vent hose and the back panal and the power cord cover.next look down and to the left and you will see a white plastic thermal fuse.remove the wires from the fuse and use a meter to see if the fuse is closed.if it is not replace the fuse and replace the back and power cord cover.plug the dryer in and check unit out.
Jan 10, 2010 | Whirlpool LER4634J Electric Dryer
Have a kenmore dryer model 86873100 the push button start quit working . replaced it ran twice now doing the same thing again . not starting
possiblethat an snapstat thermostat inside the rear panel, is kicking due to overheating. unplug, pull dryer from pipe. if vent is stopped up it will need cleaning. contact too inform us otherwise. karl
Dec 02, 2009 | Kenmore Dryers
My Profile Harmony dryer is not pushing the air through the dryer. It will heat, tumble, and the screen is working fine. We just don't have air flow through to the vent outtake.
you venting either inthe dryer or through the house is pluged check and clean external venting first and then try it. then if still acting up check the internal venting. usuall u can take off the back or bottom panel of the dryer. it is not very difficult to do but none the less becarefull and unplug the machine. and check your lint filer withevery use and make sure it fits properly. and venting is as free flowing as possible.
Jul 09, 2009 | GE Profile Harmony DPGT750EC Electric...
How to clean the duct from my clothes dryer?
if the vent is pluged dryer to out side go to home depot by the 4 in dryer vent brush with a 8 to 10 ft cabel on it feed it in the vent pull turn till it comes out the ather side you also should have inside dryer cleaned out if its pluged from the back up lint going inside dryer
Mar 06, 2008 | Dryers
My dryer wont start
check and see if you have 220 volts to your dryer using a volt / ohm meter find the cord and remove cover take meter and go across (1 test lead on left and one on right) side of cord there should be 220 volts.check this and get back to me. if no 220v trip breaker back and forth and try again
Dec 26, 2007 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer (electric)
did the button click when you pressed it when it worked fine, if it doesn't click now then you need a new button switch, which should be fairly cheap and fairly easy to replace yourself with care if the button should be pressed to start without normally clicking and needs to be pressed to restart each time you open the door then the start relay could be faulty, sound complicated but not the same fault hope i have been of some help, if so please rate me
Oct 04, 2007 | Whirlpool LEQ9858P Electric Dryer
My dryer doens't start up
Depends on if you can hear any noise when you hit the start button or turn the knob. If there is a hum or some sound then could be belt or motor problems. If there is no sound dead, then you are checking the right area, there are kill switches in different places on dryers. one is like you checked the door switch, and another may be in back when you open the cover to check. Maybe fallen out of place. These sw. are for your safety and sometimes they malfunction. Hope this help!
Aug 12, 2007 | AEG T57800 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
173 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
