Question about KitchenAid Dryers
Model KEYE670BWH0 not drying - KitchenAid Dryers
    President:
  • 949 Answers
If this dryer is running and not heating it could be one of the follow in order of most common to least common.
- Not enough power, an electric dryer uses 240 volts to heat and only 120 to run the drum. Make sure the breaker is not partially tripped or one of the fuses blown
- The thermal cut off is tripped. This is a temperature controlled fuse that trips if the air flow is restricted, usually due to a dirty lint filter or plugged vent from the machine to outside. The part is located just above the heat element accessible when removing the back panel.
- The heat element itself is bad, it is accessable from the back and is in the right bottom corner looking from the back of the machine.
- The timer contacts are bad, this is rare but can happen
- The centrifugal switch in the motor is bad, this again is rare but can happen.
If you have a an ohmmeter and some technical ability I would be happy to walk you through how to test the components.
Posted on Apr 24, 2010
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
What is the reset code for kenmore 665 1595?
Try one of these combinations, depending on the model you have (I'm sorry, but I don't know the buttons on that model):
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or if that doesn't work,
Try pressing the 3 left-most buttons in the following sequence:
1, 2, 3, 1, 2, 3, 1, 2, 3.
Jan 14, 2013 | Kenmore 24 in. 15953 Built-in Dishwasher
My kenmore HE diswasher, model number 665.1312 won't dry
is your heating element was working?,if working check the blower if working too.
Jun 04, 2010 | Dishwashers
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Washer/dryer combo- i just want to use the dryer!
You can check this by closing your faucet on the wall, & trying the spin only option. If you suceed in the clothes being dry, you have an inlet problem, replace the water inlet valve at the top of the machine, you can do it yourself. Power off the mains. You could also check out your filter & pump.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Mar 17, 2009 | Washing Machines
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Open Questions:
Dryers Logo
294 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
