Question about Jenn-Air JED8230 Electric Cooktop
The male plug on the griddle is broken.
I have researched the internet and am unable to find a repalcement griddle. I would prefer to get a new one but if I can't I need it repaired. The model number is AO310. If this is discontinued I would like to get a new plug. We replaced it in 2004 and found it at Sears.
Thank you,
Katie
  • Jenn-Air Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 18, 2010
Replacement Griddle for Kitchen aid KGCP463KSS
If Kitchen Aid is of no help, try an appliance parts supplier
Apr 21, 2013 | KitchenAid 36 in. Architect KGCP463KSS Gas...
How do I clean a Viking griddle that hasbeen
I use a product called Greasecutter Plus by ECOLAB, it makes the griddle look brand new, gets everything off. You just spray it on and let it set for a little bit then it wipes clean.
May 13, 2010 | Viking Cooktops
Want to replace / repair my 45" Thermador cooktop circa 1950? I love the griddle would prefer repair
I've got a TMH45A-1 and find that I can get most parts to repair the unit, but it really adds up fast. 6" burner is $100, 8" is about $150. Add in the rest of the parts to bring it to a like new condition and it's $700-$800!
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=233354
This is a link to a place that sells parts for my unit. If you have your model number you can search by that.
Matt
Feb 28, 2010 | Cooktops
I was given a 36" magic chef gas cooktop with griddle. It was very greasy and dirty, all the burners were sticky and slow to get turned on, but 2 of them refuse to turn on, parts lists say the griddle...
If it's two burners on the same side that won't light, it is probably the igniter for that side. If so, remove the grates, griddle, and griddle sub pan, and then lift up the main "pan (if it's like mine, it's hinged at the back and lifts up). Now, if each burner on that side has a tube going to the middle between the burners, the igniter is in that middle section. Mine is a small plug-in ceramic and metal part (see photo). If yours looks like this, contact me at jazzskier@verizon.net, I have a spare.
Nov 29, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
I have a viking cooktop with 4 burners and a center griddle. The griddle will not hold heat. It fires up then goes out.
This can be cause dby one of 2 problems.
When you turn the control to turn the Griddle on, does it come immediately or do you have to turn it a long way before it comes on?
If it turns on immediatly then it is more than likely the Ignitor
If you have to turn it a long way you have a defective Thermostat
Feb 18, 2009 | Viking VGRT600-6G Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Broken griddle control
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Jun 28, 2008 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
    Both burners turn on when only one is needed
    I just had the same problem- when I replaced the whole cartridge.
    I repalced the infinite switch- do the one that gets the hottest- or do both.
    It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
    This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
    good luck
    Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
    Jenn-Air JED8230 Electric Cooktop Logo
    63 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    jason
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
