Question about GE (PSS26MSRSS) Side by Side Refrigerator
Is not cooling I put it down to 6 but is not running
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
teyu356
Posted on Sep 29, 2010
Why wont my craftsman 25cc start
99% of the time its a carb or fuel problem. Always run premium fuel and store the machine in a cool place less than 100 F
Might can put a drop or two of fuel down the carb and revive.
Jul 18, 2014 | Craftsman 25cc Gas Line Trimmer
Car is running hot and I put a new thermostat in and water bump
make sure the radiator cooling fans are coming on. GM has also had major problems with the lower intake gaskets leaking on the V-6 engines. sometimes when refilling the cooling systems air lock can occur. run the engine until it warms up and then turn off and let it cool down, if coolant level goes down repeat this process two or three times. other causes could be clogged radiator, or worse case scenario blown head gaskets. also i have on occasion got bad thermostats from the parts store. the upper radiator hose will get very hot when the thermostat opens. run the engine and hold the upper hose and when the t-stat opens the hose will get hot. then when the cooling fan comes on hot air will rush from from the fans. if the fans come on and the air is cool then there is a circulation problem. t-stat, clogged radiator, low coolant, head gaskets. good luck.
Jul 14, 2012 | 2000 Chevrolet Malibu
I have Wharfdale 4000 Xarus speakers connected to my Pioneer VSX 817, the last 6 months it keeps saying overload when i have the volume further than 40db. Never use to do it... and i have re wired the...
Testing your amp at max with the speakers disconnected will not play a factor because there is no power being drawn so the amp is not being used. Those speakers are rated 90db and really pound but also draw a ton of amps. The key thing here is to keep it cool, cool, cool. Put a fan on it and keep your receiver on a hard surface with nothing stacked on top or anywhere within a foot of it. Keeping it cool will help prevent overloads or (protection mode). Back it down every now and them and give the system a rest for a few minutes. Double check the negative and positive connection on the speakers to the receiver. We all have hooked them up backwards sometime and this will have the effect you are expressing. What is the phase set at on your receiver? Set it down to "0" and go up to where it sounds best without distortion. One more very important thing. What is the Ohm switch on your receiver set at? Put the switch on 8 Ohm even though your running 6 Ohm speakers. That switch only steps down your voltage feed to the power selections which will hamper the overall dynamics and fidelity of your receiver. This switch is really not even necessary. Putting that switch at 8 Ohms will give you more headway and aid in keeping your amp cool.
Regards, Tony
Mar 24, 2011 | Pioneer VSX-817-S
What ratio of anti freeze:water do you put in a 318 ti sport model?
ONE GALLON SHOULD DO IT ...IF YOUR NOT IN A VERY COLD PLACE....IF SO HAVE IT CHECK AT A GAS STATION.....
Dec 20, 2010 | 2000 BMW 3 Series
On my all buttom qualink 4 on my buttons work except when I turn the spa off the cool down mode doesn't seem to work it says heater will turn off after cool down but the jandy doesn't turn back to filter...
Your heater should shut down rite away and the pump will keep running to pump cool water through the heater. After the cool down period then the valves will go back to normal run positions.
Nov 04, 2010 | Jandy AquaLink RS2/6 All Button Dual...
I have a 1988 Ford F250 4x4 with a 4.9 straight 6 engine. It will run about 15 min's then just shut down. I will wait for about one hour for it to cool off then it starts up runs for about 15 min's then...
I would replace the distributor stator and the TFI ignition module both of which are in and on the distributor. Use Ford OEM parts (Motorcraft) as after market fail very quickly.
Mar 30, 2017 | 1988 Ford F 250
No cooling effect
Dont put on maximum, it has frozen over. Your freezer cools your fridge by blowing the cold air from the evaportor coils in the freezer down to the refrgerator compartment. defrost for 6-8 hours with doors open and unit turned off. It should be fine then.
Aug 25, 2009 | Kenmore Refrigerators
1997 ford escort
thats normal if you have been running the motor its just cooling the radiator and condensor down it may run for five to ten minutes after you stop and turn it off
Jan 05, 2009 | 2004 Mazda 6
Bosch logixx fridge/freezer
please contact authorized service center for repair
Mar 28, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
99 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
