Question about Sony Televison & Video
Video cable pulled out
My dog pulled the coaxial cable violently from the TV. so that the cable guy said the problem is in the TV, not the cable. Can this be fixed??
  • 308 Answers
Yes. The connector on the tuner is probably pulled out. Depending on your skill or the skill of the repair person and the amount of damage...it MAY be repairable or the entire tuner board may have to be replaced.
Posted on Apr 23, 2010
TV intermittently loses and regains audio/video from only a couple TV channels
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 28, 2017 | Sharp LC 46SV50U 46" LCD TV
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
Coaxial cable
Most newr TV's do not come with a coaxial hookup anymore, you either need to use RCA cables for Audio and Video, Component Video, S-Video Jack, Digital Audio Jack or HDMI Input.
Jun 16, 2010 | Protron PLTV-32 Television
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
How to dismount ENG36604G tuner from CT-27D11 27" Panasonic TV
With difficulty.
Soldered to board.
Only qualified techie can do it.
Oct 05, 2017 | Panasonic CT-27D11 27" TV
Cable tech broke coaxial input off, and knocked tv over against the wall, and now no inputs work and the TV has problems even turning on . What can this be ? Can it be repaired ?
the coaxial connector you need to replace this ie just put a new one in.did he do a check to see if the tv is getting power??. with his meter??. the power supply is the most important check the fuse
Apr 23, 2009 | RCA Televison & Video
How do I hook up a dvd player recorder to my tv, so I can record? thank you DEE
Hi dbird30,
You will notice that your DVD player has two types of cables, one that is three cables in one with yellow, red and white colors; and other that is bigger and cylindrical, we call this a coaxial cable. To record from the TV you must unplugg the TV's cable and plugg it into your DVD player, plugg it where it says 'cable' or 'input'. Now you must connect the coaxial cable it came with your DVD player and plugg it into the DVD player where it says 'to TV' or 'output' and connect the other side of the coaxial cable to the TV. At the end you should see that the cable that was plugged into your TV is now plugged into your player, and the player is now connected through another coaxial cable to the TV.
Jul 12, 2008 | Televison & Video
Connecting a samsung dvd-vr to TV with cable & rf modulator
my coaxial cable hook up is broken from the plasma. Can i fix it?
Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
No cable picture or sound
only thing I can think of is for you to check your cables... assuming you are using a coaxial cable for the satelite and rca cables for games and dvds, I would recommend trying a different coaxial cable. There is also the chance that the coaxial connection on the tv itself is messed up. you may try buying an RF modulator that will convert coaxial to rca, most rf modulators convert rca to coax. so make sure it does what you need before you buy it. tech guys at store should be able to help if you can't figure it out.
Jun 19, 2007 | Toshiba TP50F60/61 TV
Televison & Video Logo
50 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
