Question about M-Audio FireWire 410 External Sound System
Just stopped working. no power. the phantom power light will still come on. but other then that, no power
    Genius:
  • 1,027 Answers
Time to replace it.
Posted on Apr 23, 2010
C1 not working
Sounds like your Phantom power supply may be defective. To be safe, 1st try moving AC plug for Phantom supply to another outlet as sometimes "sharing grounds" can be a problem. If this doesn't help, try using another phantom power source ...many PA mixers have built-in phantom power. If the buzz disappears with a new one, it will be a filtering issue (capacitors) with the old phantom supply.
Apr 19, 2014 | Behringer C-1 Microphone
Phantom Power Not working through K6
The K6 unit will require professional repair.
Nov 29, 2013 | Sennheiser ME66 / K6 Professional...
When my phantom power is turned on . my condensing mic isnt working . at first i thought it was my mic . but then i got a new one and it still isnt working . what is the problem
HAve you tried a different lead? Try a friends mic that you know works on your mixer. Its usually a process of elimination. You substitute a known working one and see what happens. Is the little LED lighting up when its turned on?
Feb 13, 2011 | Mackie ProFX8 Professional Compact Mixer
I have a condenser mic, and it needed phantom power to work, so I bought the Ultra Di-100, but I don't know how to make my mic work with it.
Sorry, but the DI-100 can OPERATE on phantom power, not supply it. If you have a mixer that has phantom power then you have no need for the DI box. DI boxes are to convert unbalanced signals to balanced to send via XLR or TRS cables.
If you don't have a mixer that has built in Phantom power or a source of Phantom power, then you need a mic preamp that can supply the phantom power.
Here is an example device, but DO shop[ around as you should find some even less expensive. Make sure they have phantom power.
http://www.amazon.com/M-Audio-Audio-Budget-Microphone-Preamp/dp/B000CZ0RZG
Dec 21, 2010 | Behringer Ultra Di-100 Active Direct Box...
What is the switch for on the Phantom power unit at the end of my AKG C747?
Hi,the switch for the phantom power on the microphone is to activation of the mic.Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantompoweronthe mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
Oct 20, 2010 | AKG C747 Professional Microphone
My f15 condensers stopped working
Make sure the phantom power supply is on and working correctly on the board. These mics need phantom power to operate.
Apr 12, 2010 | Audix F15 Professional Microphone
No sound pickup
For a mic like sennheiser ME66\K6 prof.mic.you have two options.
What might cause the blinking of the light,might be the battery,cause it functions in two ways,either by battery or by phantom power that needs to be activated by +48v power phantom on your mixer before it can work properly .
So you will do is either you get a replacement of the battery on get a mixer that has +48v power phantom power.
Jan 19, 2010 | Sennheiser ME66 / K6 Professional...
Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
Shure microphone MX418 microflex condenser 150
The mic requires phantom power from the mixer. Contact the mixer manufacturer to find out how to turn on phantom power.
Feb 19, 2009 | Shure MX418 Microphone
I have a shure microflex mic condencer 150 the led does not work and the mic is dead. Does the mic need a battery if so how do you instal it.
Try using a mixing console with phantom power ( + 48 ). A condenser mic needs 48 volts to operate. The led should light when the XLR microphone cable is connected to a console with phantom power.
Feb 19, 2009 | Shure (LX287CC) Professional Microphone
Open Questions:
M-Audio FireWire 410 External Sound System Logo
159 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
